bent over by my local MB dealer.
I took it home hooked up a hose to my IC to see if I could blow air through it (no problem). Then I put a hose to my HE and tried blowing air through it (could barely blow into it). Fifteen minute diagnostic with a rubber hose, my mouth and a clamp. Replaced the HE (Eurocharged) and everything is perfect.
Turns out the previous owner used regular glycol and the green **** corroded and clogged my Heat Exchanger. The dealership is a bunch of fools, I told the guy at the service desk prior to dropping it off that it was something other than the IC pump as it was brand new and had already been tested and determined to be operational by me. I *****ed about the four hours of diagnostics and the service department told me they had to do their own tests on the IC pump as it needed to be properly ruled out. They said that me telling them it was operational was not enough as I'm not a Mercedes Technician. Crooks!
Anyhow, I've since purchased a cheap MB star code reader from the internet, when I have problems I get a daily subscription to MB startek info and fix my own problems. That site is amazing!
(note) A regular OBD2 code reader will not read star codes.
Now do yourself a favor and get developer mode on it, more fun!
No discounting for our near-worthless W203’s labor rate. There is often a massive disconnect between a SA and the technician to whom it’s assigned. Must be noted my former SA approved several costly MBUSA goodwill repairs before being deemed redundant. You might stumble across a knowledgeable and dedicated gearhead at some dealerships, although most of them promptly go on to build successful independent service and repair businesses of their own.
Flow and pressure tested my OE replacement intercooler and aftermarket heat exchanger during the course of their DIY replacement. Figured 10+ gallons-per-minute (sans restriction) was sufficient. The first generation LET heat exchanger flows and dissipates well. Perhaps the later (C3P?) ‘turbulator’ design is more susceptible to blockage? Did get some funky debris out of its original breached intercooler fluid circuit, in spite of regular replacements using MB’s recommended HOAT antifreeze and soft water.
Consistently log less than 25° above ambient during the cool-down phase after extended WOT at closed course events.
Best wishes with yours.
Can only use US credit cards... I had some issued as a Canadian but figured my way around it.
