C55 rear differential cooling fin part number...
Old Jul 21, 2010 | 09:14 PM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
Originally Posted by PC Valkyrie
According to the C55 MB press release, the differential cooling fins could cool the differential by up to 15 degrees celsius when pushing the car at continuous high speeds.
If you don't track your car regularly, it probably isn't necessary at all. And if you're doing it for cosmetics, it certainly won't be the most obvious thing for most people to notice.
There must be some value to it, as others have done similar things. Our old '89 Maserati Spyder with a Gleason LSD had a plastic scoop to funnel air from beneath the pumpkin to cooling fins on the end plate. Porsche on their 911 race cars in the '70s had a gear pump and cooler too, though it may have been for the transmission lubrication also.
Old Jul 22, 2010 | 04:46 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
according to shops that recommend installing cooling fins is that they also help somewhat elongate the rubber parts around that area.
Old Oct 27, 2010 | 03:32 PM
Xhale707's Avatar
C320 2002
Any pictures of this installed?
Old Oct 27, 2010 | 06:12 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Old Oct 27, 2010 | 06:37 PM
Newzchspy's Avatar
PLAID
Looks good!! Make a difference??
Old Oct 27, 2010 | 08:00 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it's said to lower the diff oil temp, but i haven't done any spirited driving since i put it on.
Old Sep 29, 2012 | 10:36 AM
  #32
betrezra's Avatar
C63 507 AMG DA Car #19
Old post----- but wish to add to my clk w209. Is there still a source for the heat sink adapter plate. Or a pic of it. I can get this fabbed.
