What's the trick with opening windows on a hot day from the key fob?
Old Jul 30, 2010 | 06:56 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Can't find my book and forgot how to do this with the remote.
Old Jul 30, 2010 | 07:17 PM
Biscuit's Avatar
'03 C32, '08 ML63
There's a little square patch on or around the door handle. You point your key fob at it and hold down the unlock button. Similarly holding lock will make them go up.
For me it doesn't work on my drivers side, only the passengers, and you have to point it dead on the patch basically right on it. Wish they would've used the radio part to do it like they do unlocking the car instead of the infrared emitter.
Old Jul 30, 2010 | 07:30 PM
trbo2nr's Avatar
Cool. Thanks. I knew I did this once but ever since couldn't figure out the trick. That would explain how it worked the first time.
Old Jul 31, 2010 | 01:28 AM
loudandheard's Avatar
C32/C55 AMG
You have to be in the shade.
I remember reading that the sun can interfere with the infrared sensors and they will not respond well. You can always try it out at night to see if this theory is true or you may just have a bad sensor.
