WideBody C55 AMG Big Brake Kit 8/4 Pics..
Old Aug 27, 2010 | 11:48 AM
c55asleep?'s Avatar
Bicycle
You've learned a lot along the way Ravi lol. Car looks amazing.
Old Aug 29, 2010 | 04:08 PM
BLACKROOF C55's Avatar
C55 AMG
rollyyy!!! how you been brotha! long time no speak, give me a call when you can if you got my number still, how your trucks going!
Old Aug 29, 2010 | 04:10 PM
C55 AMG
Originally Posted by Rareamg
Sick!
your car always looked nice.. the look you got going on rite now is two thumbs up!
Old Aug 31, 2010 | 02:57 AM
c55asleep?'s Avatar
Bicycle
I will call you tomorrow.
Old Sep 3, 2010 | 07:01 AM
bennyboyc's Avatar
E350CDI Sport
Can anybody tell me what make this bodykit is? Thanks
Old Sep 3, 2010 | 12:27 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
can "c55 asleep?" tell me where he got his clk grille. thanks
Old Sep 3, 2010 | 11:07 PM
  #32
c55asleep?'s Avatar
Bicycle
I got it from ebay and it is a oem grille. I think I still have the box in which it came in, so I can give you the part# if thats any help for you.
Old Sep 3, 2010 | 11:49 PM
  #33
MIKESV8's Avatar
that would be awesome, but do you think you can posibbly send me an ebay link that's selling the one you have? i'm afraid to choose the wrong one.
Old Sep 4, 2010 | 12:54 AM
  #34
c55asleep?'s Avatar
Bicycle
Unfortunately there is no link, just someone that had removed it off their car.
Old Sep 4, 2010 | 04:22 AM
  #35
MIKESV8's Avatar
so then i would be safe if i bought an oem clk 55 grille? it would line up just fine?
Old Sep 4, 2010 | 12:16 PM
  #36
c55asleep?'s Avatar
Bicycle
Yes, you need the hood latch as well. The c55 latch is longer iirc.
Old Sep 4, 2010 | 12:21 PM
  #37
MIKESV8's Avatar
http://www.autowerks.com/product/Mif...d=p1409-c17630
i found this, and i would need to purchse the clk front latch as well or else mine will stick out?
Old Sep 4, 2010 | 09:46 PM
  #38
clemson_tiger's Avatar
2006 C55
Looks awesome!
Old Jan 5, 2020 | 05:37 PM
  #39
C55M156's Avatar
C55
Whats up bro!
I've been working on doing the same swap but haven had much luck on any info or if it was even possible, until i came across this forum.
What mods did you have to do to get the calipers to fit?:
Did the caliper bolt pattern front and rear from the 8/4 pistons line up to the c55's 4/2 pistons front and rear?
Did you have to drill out the bolt size?
Did you have to cut the front and rear dust shields to get them to bolt up?
Since its double the pistons from a c55, did you have to upgrade or change out the brake master cylinder, lines, booster, etc... to compensate for more pistons?
Did you go with 360mm rotors in the front and 330mm in the rear or use the stock c55 rotors?
Did you HAVE to go with 19's to clear the caliper or will the Sotck e55's clear the calipers on the c55?
Sorry bro sooo many freakn questions, any help would be awesome! thanks brother!
Freddy
Old Jan 7, 2020 | 02:09 PM
  #40
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Originally Posted by C55M156
Whats up bro!
Freddy
you do realize this post is from 2010 right?
Old Jan 7, 2020 | 05:16 PM
  #41
C55M156's Avatar
C55
I know, and ten years later there still isnt anything on 8/4 swap on a C55. only 6/4 swap.
Old Jan 7, 2020 | 05:47 PM
  #42
cm60k's Avatar
6/4 "CLK55/CLK63/SLK55" calipers & Rotors will 99% bolt-on,,
8/4 "55K's" calipers will fit, but needs some mods., Rotors won't fit, due to differ offset & thickness..
-;-ZAYED-;-
Old Jan 7, 2020 | 08:21 PM
  #43
C55M156's Avatar
C55
thanks brutha,
Ok i purchased 360mm rotors for the front and 330mm rears, so i SHOULD be good as far as rotors,right? and aside from drilling out the bolt hole and trimming back the dust shield, what else would i need to do to make the 8/4 fit properly? I already use spacers for the rims. would i need to go with a thicker spacer?
Old Jan 7, 2020 | 08:24 PM
  #44
C55M156's Avatar
C55
oh snap just read where it says the rotors wont fit : I
Old Jan 7, 2020 | 08:59 PM
  #45
cm60k's Avatar
Did you get 55'Ks (360x36) or Clk63 (360x32)..?
-;-ZAYED-;-
Old Jan 7, 2020 | 09:00 PM
  #46
C55M156's Avatar
C55
55k's
Old Jan 7, 2020 | 09:08 PM
  #47
cm60k's Avatar
55K's won't fit for sure, cause offset is sooooo high, which is (64.5mm),,
offset should to be (49.5mm), or max of (54.5mm)..!!
-;-ZAYED-;-
Old Jan 7, 2020 | 09:20 PM
  #48
cm60k's Avatar
And what about Rears (330mm),
did you get them from "W211 E55" or "W220 S55" or "R230 SL55"..??
-;-ZAYED-;-
Old Jan 8, 2020 | 11:42 AM
  #49
insame1's Avatar
Are you tracking this car? I have the 6 front 4 rear on my 05 clk55. I have had the 4 front 4 rear on a 03 clk55 and a 06 c55. I feel like the 4 fronts are more than enough. The cost different in the rotors and pads don't justify the aesthetic upgrade IMHO. The only reason to go to the bigger setup is looks and brake fade.
cost for 4 pin front rotors - MB OE - $250
cost for 6 pin 2 piece front rotors - Brembo after markets - $700
OE front rotors for the 6 pot $1060https://www.ecstuning.com/b-genuine-...1714210112set/
Old Jan 8, 2020 | 11:00 PM
  #50
cm60k's Avatar
(6/4) & (8/4) brakes are the one of the best performance PK upgrade that "AMG/Brembo" provides,,
4/2 brakes looks sooooo boring, and performed weak, compared to (6/4)..!!,
really not worth it to see it on AMG models..,
(6/4) are great, and fear enough for "C32/C55", and absolutely deserves to give it a shot,,
i'v done (8/6) on my 06 "SLK55", love it more, Thanks GOD..
-;-ZAYED-;-
