Lightweight rims
Old Apr 14, 2003 | 10:57 PM
Marc's Avatar
Lightweight rims
Does anyone know what the stock 17" wheels on the C32/SLK32 weigh? On my Audi S4 the stock 17" wheels weighed 28lbs a piece! I have a feeling the AMG wheels weigh considerably less...
Thanks for any info,
Marc
Old Apr 14, 2003 | 11:11 PM
JustinTRW's Avatar
C32 AMG
I don't know what the actual rim weights, but I have a spare front wheel with a Michelin Pilot Sport mounted. I believe it was around 48 .lbs, but I do not recall.
Old Apr 15, 2003 | 01:19 AM
SiLvaC32's Avatar
C32
i have no idea...... but i want to know 2. so i will know how much weight i gained from my 19s.
Jerry
Old Apr 16, 2003 | 08:46 PM
rrf's Avatar
rrf
Wheel and tire weights
I have some notes from last year that may interest you about wheel weights.
Stock AMG 17 inch split spokes, with the usual Pilot Sports:
Front 27 lbs wheel + 21 lbs tire = 48 total
Rear 27.5 lbs wheel +21.5lbs tire = 49 lbs total (data point #1)
Rear 28 lbs wheel + 22 lbs tire = 50 lbs total (data point #2
This wasn't my data , but it apparently jives with what we know for sure.
Most good 18in wheels will be well below these static weights, however when you move from a 17 to an 18 you will have to combat the "mass being further out on the rim" aspect. i.e. an 18 must weigh less than a 17 to give same performance (HP wise).
Old Apr 17, 2003 | 02:26 AM
SiLvaC32's Avatar
C32
wow..... accordin to that... my 19" rims are lighter than my stock 17s. mine is 24.5 each. does that mean i will have faster 0-60? or quater mile?
Jerry
Old Apr 17, 2003 | 12:04 PM
JustinTRW's Avatar
C32 AMG
The general formula for rotational inertia is mr^2. Even though your wheel is marginally lighter, you have to factor in the extra mass of the tire along with the longer radius. I'm guess the answer is no.
