Replaced intercooler pump with Johnson and pump doesn't turn on at all!!
Thanks..
my pump was completely shot and didn't turn on either. Just last night I replaced mine with the CM30, everything works great now! I tested my CM30 pump prior to installation. It's a long shot, but you could test to see if the pump even works?
good luck!
Maybe he checked the wrong fuse? Maybe you have a bad pump, but another way find out is to see if you have voltage coming from the wires, they are simply a positive and a ground.
Thanks everyone who responded! I love this forum everyone so helpful...
EDIT, something I forgot to mention. The CM30 comes in both 12V and 24V configurations. Make sure that you purchased the 12V model! It will be indicated on the box, the sticker on the pump as well as the user manual.
Bry
Bry
Thanks again!,
