The Official C32 Throttle Body Thread
I think this is the sl55 80mm throttle body part number 113 141 05 25 . Here's the E55 thread I found for it: https://mbworld.org/forums/w211-amg/...ng-around.html
I can't seem to find the part number for cl600. Still looking.
113 140 09 12 s/c inlet 80mmw/bypass
137 141 07 80 for the tb gasket
113 141 07 80 ls/c inlet gasket
113 140 01 04 for 80mmTB
113 094 02 03 for elbow 80mm
113 141 15 80 for elbow rubber gasket
https://mbworld.org/forums/w211-amg/...rs-please.html
The E55 throttle body was a drop in replacement for the C32 throttle body.
This was great since I couldn't find a used C32 tb and new ones were ~$1500. A new/rebuilt E55 tb can be found for about $250 online. Used ones go for even less with the e55 guys upgrading to larger ones.
i attached pics in the thread " dyno results".
of course when i mentioned no afr change i mean at full throttle at fourth and fifth gear to 150 mph not at idle!
I noticed in the pics you posted in your dyno results thread that the bottom y-pipe connected to supercharger looks like it was coated. Did you have the bottom y-pipe ported and then powder coated? Nice touch with the heat shielding.
The boost is the same, AFR the same and hp/tq are the same. the 74mm tb is sufficient on my car.
the bottom y pipe is the stock one, i didn't touch it.
The last item left is the tb. I purchased the E55 tb & installed it on the 8th. I plugged the male plug from the original connector into the female end of the plug off of the E55 tb. This was because i was unable to reach the other end of the original plug. Either way after the install the car ran great for 1 1/2 miles then went BACK into limp mode. I've been thinking about using the tb out of the srt-6 crossfire because it is significantly less expensive. (Original quote for $1,300 for C32 tb 175 for srt-6 tb)
Ideas? Any help would be appreciated!!!
Are the c32 throttle body replacements : 112 141 0325, 113 141 0125, 112 141 0125 ?? Some assistance please in correct p/n for an E55/ C32 that is the 74mm. it seems that the 112 141 0125 is a 64-68mm? Some help please? Chhers,
Do you have any symptoms?
