Kleemann K2 in the making
Old 10-24-2010, 12:17 PM
  #201
Newzchspy's Avatar
PLAID
Originally Posted by alroumi
Thank you guys, will be waiting for Kleemann's response. I've sent them a copy of the dyno, I am pleased since the leaning out is accomplished and its running rich again. I agree with all of your comment, I think they can get slightly more power but maybe its true or maybe not. I think the weather plays a vital role, will see what the outcome is. I also plan to get the K3 which consists of the camshafts and also I want a Quafie LSD.
Should have done the cams b/4 you did the install?? Now you gotta take the whole top off again. I hear they don't give much, 10-20 rwhp if that?? Ask Mike, Alumar, I think he's got the cams in his?? I still haven't done my Quaife, which has been in a box for about a year now??
Old 10-24-2010, 12:20 PM
  #202
Newzchspy's Avatar
PLAID
Originally Posted by ABALONE
Congrats on getting the car to work! Now get a bigger heat exchanger and separate the IC cooling with a separate expansion tank on the driver side and let the water flow from side to side through the HE. Stock Kleemann heat exchanger system is actually not such a great system, a lot to improve there.
// Magnus
+1, Chicago Performance told me the same thing about the Kleemann cooling? A C32 HE would do just fine if you can get one from Eurocharged or HP??
Old 10-24-2010, 02:07 PM
  #203
betrezra's Avatar
C63 507 AMG DA Car #19
Corey told me the kleemann h/e is adequate for even the hottest climates. He's got cars running kleemann out of the box h/e with no issues in Az, and So Fl.
We'll see how it works out next summer in Hot Houston weather.
I don't plan to hot lap this car, and if I get heatsoaked in houston traffic, I realize I might have to cool things off by running down the highway a bit, before WOT runs. Not a big deal for me.
Old 10-24-2010, 02:26 PM
  #204
alroumi's Avatar
G55 & SLK55
I've asked Kleemann a while ago about H/E they think its more than enough for the hottest climates, I am just waiting for their response in regards to my tune and dyno. I still think there is more to do, might need a re-map to sort out the A/F and get more power out of it.
Old 10-24-2010, 04:50 PM
  #205
betrezra's Avatar
A revised H/E setup might be necessary if your start over spinning the blower with a smaller pulley.
There are other options as well..... methanol injection setups, or a mister sprayer on the h/e at the front bumper. Or a nice small shot of NOS 25-40hp has a good cooling effect.
Old 10-24-2010, 05:04 PM
  #206
Newzchspy's Avatar
PLAID
There are about 5 guys I know , including myself, who have "55 engine Kleemans". All of them run rich for some reason?? I know that mine, Mikes and another guy in FL run very rich. I hear that Jeremy at OT Tuning can tune the engine so it doesn't run so "rich".
Old 10-24-2010, 05:22 PM
  #207
alroumi's Avatar
G55 & SLK55
Anyone with a Kleemann blower can post a dyno, I just want to compare and use as a refrence.
Old 10-24-2010, 07:34 PM
  #208
alumar's Avatar
2019 E63s AMG
alroumi,
I will post the Dyno Charts from Kleemann's Dyno tune I had in May ... they did 46 pulls with it, should give you some good data. Let me see if Cory will make one PDF with them all in it.
I was pulling a 380-400rwhp on dynamics dyno when my A/F was real rich, after the kleemann rebuild i had 70 more hp ... My blower though is the older autorotor version, twin screw lysom .. not the eaton verson.
Old 10-25-2010, 07:38 AM
  #209
alroumi's Avatar
G55 & SLK55
New update:
I was just told from kleemann to drive the car and see how the ecu adapts within the next 1000km
Old 10-25-2010, 11:38 AM
  #210
ABALONE's Avatar
2001: Supercharged E55 AMG
Ofcourse Kleemann will tell you that their HE is big enough for all the weathers in the world. But it doesn't take that much of a scientist to see that it's to small when you look at it! Not only that it's to small, you loose a lot of water flow/cooling when you let the water in/out on the same side as they do on the stock Kleemann HE.
Look at a front mounted air IC, they doesn't let the air in/out on the same side for one reason (cooling). So the best solution is to the same with water and let the water in from one side and out on the other And it doesn't matter how much boost you are on, you will loose cooling even if you are at stock pulley (2.8").
// Magnus
Old 10-25-2010, 12:03 PM
  #211
Newzchspy's Avatar
PLAID
Originally Posted by alumar
alroumi,
Mike, how in the world did they get "70 rwhp" more Hp out of the car?? I too have the Autorotor and would love to see how they did that?? Did they give you any data, change the MAF or re-tune?? I know that you're running a "smaller" pulley and that should account for about 20-30 HP.
Looks like someone (moi) is taking a drive to CO !!!
Old 10-31-2010, 05:48 AM
  #212
alroumi's Avatar
G55 & SLK55
Just drove the car, lots of traffic didnt feel very fast but when I got it on the highway I was able to hit 240kmh much quicker than my old attempts without the supercharger.
Without the supercharger I might just hit 200-220 barely, even when I slowed down in the K2 Kleemann I think the stock car needs a couple of more seconds to go to hit 240kmh.
Highway pull seems fast at top end, it is a hot day today and lots of traffic so couldnt get a clear verdict. I asked the tech if it felt fast, he said yes. However, behind a wheel its like playing Granturismo or Forza its that easy to drive at 120kmh beyond below that esp light comes on a lot.
The power delivery felt very linear, in a good way it feels very oem for a modified car.
Old 10-31-2010, 08:01 AM
  #213
betrezra's Avatar
Glad it feels very OEM.
Old 10-31-2010, 01:33 PM
  #214
alumar's Avatar
2019 E63s AMG
I think it had a lot to do with my A/F issues... i was running pig rich.. south of 10.0...off the charts
After the rebuild and A/F issues resolved holds strong 12.3-12.7 through the range, it was a major increase in power.
Old 10-31-2010, 03:33 PM
  #215
alumar's Avatar
2019 E63s AMG
Here is the Dynamic's Dyno when my A/F were F'd
Here are a few vids i made the other day ... to show accel and what happens if I try full accel around 40... blows the tires off...
55 to 100
http://www.youtube.com/watch?v=F6xpm4ozHRQ
40mph FT ... ESP off
http://www.youtube.com/watch?v=2vOFCLPNDfc
Old 11-01-2010, 04:56 AM
  #216
alroumi's Avatar
G55 & SLK55
Got the car back today:
I've got many good things to say:
1) Drives like oem
2) No heat generating through traffic, temps consistent like oem
3) Power delivery very smooth for a Supercharger no sudden boost curve or lag
4) I couldnt hear the supercharger whine my exhaust system is too loud.
End product:
Uploaded with ImageShack.us
Note to self: Traction control always on due to :
0-140kmh spinning
Gets the tail-out as little as 2,000rpm
Side shot:
Warning for service tech's comes with all Kleemann kompressor kits:
I'd like to applaud member Rouven036 who is my friend and tech, he did the work and is a quality install.
I absolutely love the car.
Old 11-01-2010, 12:28 PM
  #217
Newzchspy's Avatar
PLAID
[QUOTE=alumar;4329713]Here is the Dynamic's Dyno when my A/F were F'd
55 to 100
WOW, you can hear it in the videos!! Great acceleration!! And to remind everyone, thats with a Quaife LSD!!
Thats it!! My cars going to Kleemann for some "tuning" You dyno chart is identical to mine with the A/F ratios.
Old 11-02-2010, 06:41 AM
  #218
alroumi's Avatar
G55 & SLK55
What LSD's are out there, I know of Quafie, Brabus and Kleemann.
I just spun both wheels at 80kmh, downshifted to 3rd with esp off and the car nearly jumped to the next lane.
Old 11-02-2010, 04:22 PM
  #219
alumar's Avatar
2019 E63s AMG
That statement there is an appropriate time now to say, Welcome to the Club... Ever seen my burnout vid in signature? Thats in Dyno Mode, WOT .... vaporizes the tires
Old 11-02-2010, 04:29 PM
  #220
Newzchspy's Avatar
PLAID
Mike, even ESP off and in "S", my car just annihilates the tires!! Even better when its about 40 out and the DAs are off the charts great!! Kleemann's just love "cold air"
Old 11-02-2010, 06:08 PM
  #221
betrezra's Avatar
You guys are killing me!!!!! (my car has been in the shop for these mods for almost 2 months)....... can't wait for the POWER>
Old 11-02-2010, 06:11 PM
  #222
alroumi's Avatar
G55 & SLK55
To be totally honest, I quiet liked the feeling of spinning the wheels at 80 kmh, it just shows you how much of monster the car is. Even at 140 the esp light goes on, It pulls like crazy and reaches speeds of 240-250 much easily and quicker compared to the stock car.
Old 04-03-2016, 08:09 AM
  #223
alroumi's Avatar
G55 & SLK55
Just sent my ECU to Eurocharged they did a good job with my G55 tune and now adjusting my SLK55 A/F ratio hope to get another 20 or so HP out of it with correct fuel distribution.
Old 04-03-2016, 10:19 AM
  #224
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Did you mean to put this in a 5 1/2 year old Kleeman thread?
Old 04-04-2016, 01:42 AM
  #225
swedepat's Avatar
2011 C63 AMG, 589hp
Does it matter?
veterans on forums are shouting 'search' and then this..
I´m confused.
Quick Reply: Kleemann K2 in the making
