Johnson CM30?
My question for you is, how can you mount it verticaly as there is simply NO room
Although I still agree with you my friend
PS: I did mine in less tha an hour as well. It really isn't that hard guys. Pain in the *** yes, difficult no.
anyway, I mounted mine as vertical as i could. The problem was that the oem hose wasn't long enough to accomodate the 90 degree position. I also recall having alot of room. as far as repositioning the pump, I am almost positive that I used only one of two holes from the original mount position and used a self tapping screw for the other to hold in place after turning it up to almost 90 degrees. (did this a few years back....sorry for my poor recollection.)
TO THE OP , the best tip is to use either the smallest c-clamp or vise grip to remove those PITA hose clamps. and 2 wine bottle corks to prevent coolant loss.
John
http://img560.imageshack.us/img560/9...0915185934.jpg
http://img695.imageshack.us/img695/7...0915185940.jpg
http://img839.imageshack.us/img839/3...0915185958.jpg
Replaced fuse 5 in trunk and 51 in engine, but still no sound from the pump. If I take it out for a hard spin tomorrow, and it goes limp, I'm done with this car. Had it for 7 months and no mechanic can figure out what's wrong.
keep us updated
So hows is the car? i'm having this problem, been told to bleed the coolant properly and get all the air out of the system.
This S/C cutting out is really PITA
I didn't bleed the system, I just drained it when I removed the old pump since it was hard enough to get it off, trying to keep the fluid in the system would have been near to impossible. After I put the new one in, I just topped off the coolant, and it's been good since.
Obviously for someone just doing maintenance this doesn't apply.... for anyone doing this as a performance upgrade, do the intercooler radiator (heat exchanger) at the same time and remove the bumper, it looks heaps easier to get at the pump.
