Eurocharged Heat Exchanger Pics/Review
03 g35 coupe...........02 c32 Sold
i just got mine from parts.com for $350 shipped. It definitely pulls harder in the upper rpm with the sl55 intake. Mid and low range power seems to be the same. I should have a dyno next week when jeremy can retune my car.
C32, 911 SC
I was piecing together the intake from the part numbers that you provided in another thread last week. Tempting, but just have to hold back ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Keep us updated with the retune! I am planning to do my dyno runs soon enough.
OP, I apologize for the OT, but I am sure you would want the SL55 Intake to compliment that HE
I do! although with the recent posts about the flow tests of the air....looks like I am leaning towards the FMU intake setup...which looks pretty cool as well
Quick question. I see you left a half inch or so gap between the impact bar, and heat exchanger. Was this required or just how you ended up mounting it? I bought a heat exchanger 26x7x2 and need to make brackets for install.
Forget that question. Looked at the photograph again to see it's less than half an inch and after replacing my radiator today I know there's two tubes running under the impact bar... Can't wait to get this new heat exchanger installed! Another question however. Can I make a bracket which sets the heat exchanger back towards the engine more? That way I have room to install some fans...
#32
I finally had mine installed and it only took me 9 HOURS!
Removing the bumper was a big PITA by myself and cutting and measuring all of the aluminum sheets to mount it to the radiator support was an even bigger PITA. I added a peace of mind with two zipties mounted to the crash support![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
I checked for leaks and was fine when the car was not rolling. I then installed the bumper and everything else and did a quick run. When I got home and pulled into the garage the damn thing leaked like crazy from the two hoses![action](https://mbworld.org/forums/images/smilies/action1.gif)
So I had to remove the bumper again, which only took me 10 minutes this time and fixed the leaks and everything is great.
A quick review though, the car pulls constantly with HE, even in 95 F weather. I didn't know what heat soak was until I felt the difference with HE.
I absolutely LOVED it, definitely a "must get" for C32s especially if you're modded. Now onto dyno runs and get comparos with stock.
![Bump](https://mbworld.org/forums/images/smilies/bump.gif)
#33
DMAN!! lookin nice nice nice =]
YO! where did u get that windshield cover???
