C32 balljoint problems?
Nevertheless, OE Lemförder hardware is preferable to eBay knockoffs.
Might as well specify MB’s retrofittable CLK BS bushings during refurbishment.
Torque arm (#90) is the semi-longitudinal aluminum piece; the iron thrust arm (#140) perpendicularly counters the steering knuckle’s hub-level lateral forces:
Was compelled to also replace the rack’s outer and (subsequent to this photo) inner tie rod ends’ ball joints:
Aforementioned torque arm bushing upgrade:
Did fit fresh Bilstein’s a hundred thousand ago though.
I’ve zero experience with a Dakota, but the GMC’s underpinnings are still going strong after 230,000+ workaday miles.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
http://www.rmeuropean.com/Part-Numbe..._C1F643E4.aspx
Get it up on a lift or alignment rack in order to verify the source of its “clunking/rattle.”
The upper strut mounts, anti-roll bar bushings/links and inner tie rod ends also died an unpleasant death on mine before 50,000 miles.
Each contributed in its own special way to untoward looseness and noise. Pleased to report it currently drives along quite solidly.
