Anyone else NOT impressed by Fuchs 4134 ATF?
Old 11-28-2017, 05:41 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Speculation and my own research says that yes, the MB was made by Fuchs, but it can't exactly be confirmed
Old 11-30-2017, 03:54 PM
mer250glk's Avatar
glk250
Ladies and Gentleman,
I have been reading all the threads about transmission service for my 722.9 transmission (2015 GLK250). Pardon me! but I am still confuse if I have to use the red or the blue transmission fluid.
Old 06-06-2018, 09:20 PM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
The characteristics of ATF change over time. Do a TCU reset and all will be fine.
Old 09-29-2019, 05:58 PM
Brian Nelson's Avatar
2007 W211
TCU reset necessary
It's always important to reset your TCU whenever doing a TFF.
Old 01-16-2020, 04:50 PM
ncitizen's Avatar
W163 ML350
NEVER reset any adaptation values in your Mercedes transmission, unless you have rebuilt it with changing mechanical parts inside it.
Fuchs 4134 is approved by MB and it cannot behave differently compared to OEM.
The reason your driving experience might differ after a fluid change is the fact that 5 and 7 speed transmissions are always adapting to multiple parameters/variables that have changed after fluid/filter replacement. For example, clean fluid can flow much better and faster through a new clean filter, and go through all the components in faster periods of time compared to old fluid and dirty filter.
It takes time for the tranny to adapt to these new values, which can take as long as 5000 miles and even more. There's no way to avoid this. Resetting adaptation data will only kill your transmission faster.
Old 01-17-2020, 08:09 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
id like to know where you got this info from. i have done tcu resets plenty of time as well as many people on this forum for many years with not noticeable issue. In fact sometimes it it the answer to a transmission that is acting funny. Every have your battery disconnected for more than 15 min or so? reset.
Old 05-08-2021, 01:08 AM
  #32
Steven Mott's Avatar
00 s430
Fuchs 4134 atf
Originally Posted by Viper98912
Did a pan drop and filter change this past weekend and put in the latest and greatest Fuchs 4134 ATF that should be compatible with the 5 speed. Well, it might all be in my head, but it feels like my 1-2 shift is definitely much slower now (especially under low-medium load) and the higher 3-4-5 shifts are a little bit harsher (but not necessarily faster).
I bought 12 liters of the stuff and planned to do another drain and fill this weekend to try to get out some of the remaining old stuff, but I'm wondering whether to scrap that idea and go back to the traditional 5 speed fluid....
Maybe might help to repeat the trans"reset" through accelerate peddle.Im gonna service mine tomorrow with Fuchs I'll let you know what I think..
Quick Reply: Anyone else NOT impressed by Fuchs 4134 ATF?
