What is the typical charging voltage?
1) With the car running, the voltage across the battery is 14.12 volts.
2) With the car not running after the first day and inside the garage, the battery reads 12.38 volts.
3) With the cst not running after the second day and inside the garage, the battery reads 12.41. volts.
My question is, what should the running voltage be? And, could I have received a less than perfect battery? If the running voltage is low, does that mean the alternator or voltage regulator is going bad?
This is all using the info in the instrument cluster rather than reading it using a voltmeter.
