RPM Idle after Gaskets change and Spark plugs.
I just changed my spark plugs and gaskets today.
After I drove car to home from the shop.
I put my shift on P and RPM idle was not stable.
It was kept moving between 1000 and 1200.
My friend suggested me it might be misfiring.
Need your help guys.
Thank you!
any cel?
idle should be about half of what you indicated
look for vacuum leak or if you removed the intake tubes to get at the plugs
check that it is seated fully and no intake leaks.
misfires you would have a check engine light and p0300 range misfire codes.
really looks like a leak though
also check that you did not knock off any vacuum lines
