Test drove a C55 today
It's the first C55 I have driven or as a matter or fact, the first Merc I have driven in my entire life. I've been loyal to the japs ever since, well until now... ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
From a full stop, acceleration and torque just made me grin ear to ear.
However, when rolling around 20-30 or so and then I decide to accelerate a bit harder (just short of flooring the pedal), I noticed that the tranny doesn't downshift to a lower gear that I would have preferred. So it felt like accelerating from 3rd gear... Is this normal? Or did I test one with a bad AT? The care had 53K miles and it was an 05.
Oh shoot, it occured to me just now that the car might have been in "normal" mode! There should be a Normal/Power or Sport mode switch right? I just snuck out of the office so I was in a bit of a hurry that I didn't have time to check all the buttons and features of the car![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
Would having it set to Sport mode cure the sluggish 20-30mph rolling acceleration I experienced above?
There are three (3) modes, S, C and M. The S is sport (normal), C is comfort and M is manual!!
Thanks! And the Sport mode should give me the more aggressive acceleration and downshift that I was looking for right? How does it behave? Will it also hold gears longers?
Anyway, that's the first thing I'll set on my next test drive.
By the way, I also noticed that the car didn't have a "V8 Kompressor" badge on the side trim. I thought all C55 AMGs had them. Is this okay, or is this a sign of tampering/repair?
The E55s (W211), SL55, CLS55, S55 (depending on yr), CL55 (depending on yr) will have the V8 kompressor. Oooo and some G55s too (depending on yr)
The C32 and SLK32, for comparison and reference purposes, has a Kompressor V6 badge
1 Post
C55 AMG, 135i, 911 GT3, GLE43 AMG
A few other comments about the transmission:
In S or C modes, there are 2 ways to guarantee a downshift everytime. You can manually downshift (using the left shift button on the steering wheel or nudge the shift lever towards the left). If you hold the shift button or shift lever for slightly longer, it will donwshift to the lowest possible gear to get maximum acceleration given your current speed and rpm's.
The second way to guarantee a downshift to the lowest gear for maximum acceleration is to floor the accelerator all the way to kickdown.
Outside of these 2 options, the response of the transmission to throttle inputs will depend on several things. The transmission mode makes a difference. In S mode, the transmission is generally more responsive to throttle inputs; it will hold a gear to higher rpms's before upshifting, it will automatically downshift with aggressive braking etc, etc. However, the transmission is "adaptive", meaning that if you have been driving very non-aggressively, automatically downshifting will not be as responsive as it could be. In its most aggressive mode (when I've been at the track for a few laps), I can make it downshift with minimal throttle input.......it's quite impressive actually.
In C mode, the car will behave like a non-AMG Benz slushbox. It will upshift at the earliest moment; it will start in 2nd gear, etc, etc.
In M mode, the transmission won't do anything on its own (other than downshifting to prevent stalling). You have to shift yourself.
Oh okay, so Kompressor = SC. I guess I was looking at a C32 then (and thought it was a C55) when I was online shopping yesterday.
Gee, after reading your replies, I realized how stupid my questions sounded... so thank you for patiently answering them. I've just set my eyes on this particular model last week so I basically have zero knowledge on it.
Anyway known major issues with the C55s? Like the SCs in C32s and the ABC suspension on E55s?
Early versions of C55 (2005) were known for leaking oil from under the transmission. There may have been a recall on that, but not sure. Leaking oil from the air boxes is also pretty common across all models. The seals on the air boxes are silicone and break down over time. Make sure the car isn't leaking oil anywhere, but if it is, a reseal is a pretty simple fix, nothing to worry about.
Both the C32 and C55 are awesome cars. Whether you're going to a wedding reception or the race track, they're appropriate for the occasion
Hope you find a good one, good luck!
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
1 Post
Aston Martin V8 Vantage
they are amazing cars and i'm so glad i bought it! all my other choices don't even compare to this car. easy way to fix your issue, if you do buy the car, turn the key to the on position, hold the gas pedal down for five seconds, let go of the pedal and then turn the key one more time to turn on the car. you'll see a difference
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2016 Chevrolet SS, 2006 Cadillac STS-V
Make sure you were hitting the kickdown. When you push the pedal all the way down, there will be another "click" to push it down more and it will downshift as low as it can. Otherwise, it will usually only downshift one gear if you don't hit the kickdown.
There isn't anything major to really worry about on the C55 since there isn't any supercharger to put extra stress on some parts. The valve covers will probably leak and the motor mounts will go at some point depending on how you drive the car. Mine also had a rear main seal leak. And a common W203 problem is front suspension bushings. I would definately inspect or have the car inspected to see if any of these problems exist and have the price of the car adjusted accordingly.
Unless its a Kleemann SC, it should NOT say Kompressor on the C55. Thats for the C32 and E55.
The SC is NOT an issue on the C32?? Modded ones can have bearing issues, BUT there's guys running over 100 K miles with NO issues on their SCd cars.
Sorry, I just based that comment on what I have read/researched in this forums. I remember coming across a numbers of posts saying that C32s "eats" SCs every 50k miles or so.
2006 C55 AMG
BTw original Sc on my 100k miles c32.
It was done at a dealership. Once serviced, does that take care of the problem once and for all, or is the tranny really bound to leak every 1-2 years?
How much approx. does the dealership charge to fix leaks (tranny, air box, rear main seal etc)? How about the motor mounts and suspension bushings?
I requested for the car fax of the one I tested earlier and indeed there was an entry "automatic transmission oil leak checked" back in Dec 2005.
It depends on the location, some places have a higher labor rate and some dealers and nice with parts pricing and others are not. However, as usually the case is with seals, the parts are cheap but the labor is a killer. For a rear main seal the transmission will have to come out. However, it really depends on how **** you are about leaks. Unless it's pouring it may not even be worth fixing. I had a year of warranty left when I bought my car (which was what I wanted to work out all the kinks since I had no plans of buying an extended warranty) so I got mine fixed. The valve cover gaskets were leaking pretty good so it kinda covered up the rear main seal leaking (which wasn't really leaking that bad) at the time.
If the previous owner of the car was watching for leaks, they've probably been fixed already. Like I said though, definately have them lift up the car so you can check out underneath or take it somewhere and have it inspected. These are overall very good cars, but there's still always a chance of something crazy.
Not really, the only place on the transmission that leaks is the connector. But the part is like $10 and doesn't take long to replace.
Thanks! Makes me wanna limit my search options to the ones that still have extended warranty... though it will cut my selection drastically, and these cars at not that common to begin with
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
It's also only got 26K miles on it (warranty also expires when you hit 75K).
Check out my thread:
https://mbworld.org/forums/mercedes-...ay-2013-a.html
You're in luck! I just put mine up for sale--with Mercedes Extended Limited Warranty (not aftermarket) until May of 2013.
Did you track this car btw?
Here's what might be another newbie question... I've never bought an out of state car before (your in PA and I'm in IL). How does it usually work? Does the buyer usually fly/drive over and have the car inspected at the seller's local dealership?
If any other members who have done this before could give me tips or share their out-of-state car buying experience, I would really appreciate it.
08 M5, 06 X3, 05 C55
Hmmm... really tempting. Although I really prefer brilliant silver or gray, but black is 3rd on my list. Interior shots would be nice too.
If any other members who have done this before could give me tips or share their out-of-state car buying experience, I would really appreciate it.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
since this car has extended warranty, I wouldn't worry too much about inspecting it. I would just make sure the wear items are in good shape (brakes, tires...etc) maybe check to make sure the warranty is valid and get a copy of the service history?
As much as I intended to get her to the track, I never actually did...no road racing, drag racing, auto-x, etc.
I actually did purchase this car out of state, and I'm pretty sure that the rules vary state to state.
In my situation, I bought in MA and live in PA. PA would not grant a temporary tag until the car was here (which didn't help me much) and MA would not grant temporary tags for cars not being titled in MA. So I flew in to MA, inspected and purchased the car. The previous owner let me use his tags to drive back to PA. Once there, I titled in PA and then mailed back his MA tags.
So you should definitely check with the Illinois DMV to see how they handle out of state cars being brought to IL. It would be easier for everyone if Illinois will provide temporary tags once you buy insurance on the new car. Then you use the tags on the trip back--and then title the car in IL.
I would certainly recommend a local inspection prior to purchase. MB of Cherry Hill, NJ or MB of Fort Washington are closest, but you could choose any mechanic you preferred.
I do have the service history as well.
