my warranty ends in 3 days, putting my car in stealership in 2 days. need help.
i have been following this forum for a while now and have noticed that the most common problems in the c55 is A) the seat warmer B) the motor mounts. should i check anything else and bring it to the attention of my service advisor that day? it's my last shot. thanks!
On my c32 I was told this this was normal, it was one of pumps priming before the car start. I think it was the SC pump but not sure. If you have it then it is not the SC Pump.
It does it before you start the car correct?
no it does it in the morning for about thirty seconds when i start the car. not when the car is off. i know that when you turn the key to the on position it makes that noise, i knew that it was normal, but had no idea it was the pumps priming. thanks
Thats pretty scary. I have the same problem with the weather stripping on the window, the whining of the engine, and the lack of warmth on the lower seat warmer pad. Just passed 30k miles, and looking at engine mounts + transmission flush next.
Thats pretty scary. I have the same problem with the weather stripping on the window, the whining of the engine, and the lack of warmth on the lower seat warmer pad. Just passed 30k miles, and looking at engine mounts + transmission flush next.cylinder 7 as well now. they don't have an idea, but they don't hear or feel it while driving so they're clearing the codes. it's probably a spark plug going bad (which stealership wants $1,100 to replace all of them) my bushings look good, they're replacing the front two motor mounts and the tranny plate is fine and they are getting me new bottom seat pads for the two front seats. the car should be done tomorrow. i recently got robbed for $1800 so i'm gonna have to wait before i change all my spark plugs (certainly not at stealership) and get my oil changed. i have a $350 tune coming up on the 8th while i'm in vegas.
yes sir. i'm not that worried about it because you can't tell they are. maybe it's shooting them these codes for god knows why. all i know is that every 5 years on this car you're supposed to replace the spark plugs and 5 years will be tomorrow for me (my service advisor is the source) i'm still freaking pissed about having my money stolen and i have an idea who took it so i'm gonna see if i can get that back first and then i'll go from there. i'm gonna get a quote from my mechanic to see what he'd charge me for the spark plugs and to change the oil.
Any why don't you keep your money in a bank?
If it like here in Miami there are plenty of disgruntled MB mechanics who used to work at the stealership that opened up their independent shops
YOu should be paying $100 for a oil change for Mobil 1 Synthetic
and maybe $ 250 +/- for the park plugs (remember you need 16)
You should ask the dealer why they want to charge a day's worth of labor to change spark plugs. If they want to do it faster, they should probably look it up on youtube.
1) OEM plugs or research what worked best for folks on here, 2 plugs per cyl, so 16
2) Get a LONG extension for a ratchet ...im talking like 12" for a few of the plugs, with one having a 90degree adjustable swivel .. makes things a bit easier ...
Pull off top cover, air intake ... then pull all of the coil packs off, follow the wires from them to the plugs... pull the plugs, take note of the ORDER the plugs are plugged in from each coil pack.
IF your misfire contiunes after you replace the plugs... it could be one of your wires coming from the coil pack OR the coil pack itself.
Someone here can probably tell you the exact "GAP" you need on the plugs.... just dont buy and put them in, make sure they are gapped properly
Gap tool is at any autozone/pepboys etc for about 1 dollar ... normally by the checkout counter. Standard Metric Ratchet set should work with that extension. It also helps if you have some extra large needle nose plyers to get a good grip on the end of the coil pack wires, where they attach to the plug, just get a solid grip and slowly pop off each coil pack wire from the plugs
If you were in the area I would tell you to bring a 12pk of beer over and I would help you :P Dont mind helping out a fellow MB brother
thanks again for the help!
FYI also make sure they check the secondary air injection. That is a pricey little bit on the AMG cars. Although in CA, you might be covered more comprehensively by the Federal Emissions Act (search, its good stuff). The dealer right now wants $1,100 to replace mine. The CEL will light up, but its not critical to the operation of the vehicle. There was also a TSB that came out in '06 for '05-'06 AMG models to upgrade the ECU, which was causing the fuse to short, and the pump to burn out.
