C32 Fuel Sender Problem. Help?
http://www.installuniversity.com/mb/w203/w203/fp.html
I looked at my '04 C32 and here's what I found in the car:
A203 470 1741 -left- Marwal Systems 0975 303 9902
A203 470 2494 - right- Marwal Systems 0975 203 9906
Upon a parts search I was appalled.
It seems the left unit is $450 and the right is over $1,100
It seems the units are normally about $500-$600 for the pair but these are specific to the C32...
I couldn't find anyone complaining about that on here, which doesn't seem possible given the outrageous cost, so I'm hoping that you guys may have already worked out a better solution...
Any help/advice? Has anyone encountered this problem on a C32?
Lock Technology LTI940 Gas Tank Fuel Pump Removal Tool
Sold By: UnbeatableSale.com, Inc.
SPM222404880
I opened my passenger side fuel tank first since I didnt have to disconnect the fuel lines etc. When I opened it ( recommend that the tanks are NOT full, makes for a headache) I had to drain the tank, upon draining it my brother and I noticed the fuel level float was stuck in the air, it wasnt sitting on the surface of the fuel. My brother touched it and it fell down. We messed with it some to see if it was hanging up and found it was so we tweaked it ever so slightly and tried again and had no issue. So we put everything back together and filled it back up. I also added some fuel system cleaner and ran it through. The first tank was sketchy but after that it seems to be accurate but I can only get it to read 7/8 of a tank and not actually full. I need to replace my sensor unit once I get a chance to break away from work. I just made a 1200 mile road trip and it seemed to read pretty accurately in regards to the needle recording the amount left vs range left on LCD display.
The fuel pump assembly itself looks to be a very interesting task to take on, one which I will be tackling hopefully in the next few weeks.
As for the price of the sensor look on google, I found some far cheaper than that and they were OEM parts not chinese knockoffs. I will try to find the site.
***As a side note to clarify the "tweaking" of the float arm, my brother and I are both mechanically inclined, I myself am a mechanical/PLC engineer and he is a UTI trained mechanic as well as a USAF F-16 crew chief, it was to see if we could stop it from hanging up. So you are more than welcome to try this if you want, just wanted to clarify it wasn't weekend backyard mechanics doing this.***
Andrew
I figured I would mention my occupation just to add peace of mind for some people, didn't want them to assume that we just started bending stuff on a whim.
