I need to replace my front sway, what brand/thickness is best? Should I replace F+R?
Last edited by ByeTurboS4; Mar 2, 2011 at 08:09 AM. Reason: cars get me too excited to spell correctly
I'm still on stock AMG bars - thought about changing them for a long time, but just haven't done it yet.
Now I could see an upgrade to the rear helping out.
Anyone here have any first hand experience with upgraded sways on our cars?
You are absolutely crazing if you put a bigger front bar on and leave the rear stock
It will plow like a pig on the track , and leave much to be desired on the street.
TruTaing-Thank you this is exactly what I needed.
So if understeer is such a problem should I replace the front with Oem and and a big sway in the rear. Or the smallest sized upgraded front sways with one of the thickest rear sways, would that work. Could anyone else with real c32 suspension experience weigh in here?
Now with the 235/275 tire combo and -1.5 camber, the car is pretty neutral until I hit the gas.
Front
http://www.lpiracing.com/Mercedes-C3...0330p74126.htm
Rear
http://buyloweringsprings.com/catalo...products_id=95
Do you or will you track the car? You won't really notice the difference on the street. If you're not going to track, why would you want your car to oversteer anyways? Keep everything stock. I wouldn't recommend you do anything to the sway bars till you drive your car and get to know it a bit better. Seems like you don't really have it on the road yet? It's a good idea to get some stiffer suspension before you think about going with thicker bars. I'm not a huge fan of throwing thicker sway bars into the rear to get the car to oversteer. Something about it feels unnatural like playing with tire pressures. Don't take everyone else's word for it. Drive the car and form your own opinion on what you think needs to be corrected. Some people prefer a car to understeer more. Personally, I have the C55 suspension and an H&R rear sway bar. The C32 does tend to understeer during track conditions. However, in auto-x where the weight is being thrown around more, you can easily make the car oversteer with power oversteer. There's more than enough torque to do this.
Bry
I think I'm gonna go with H+R front 26mm and eibach rear 24mm-recommended in the very helpful DIY for the sways-https://mbworld.org/forums/c-class-w203/171736-diy-front-rear-sway-bars.html
