DIY transmission replacement possible?
02 C32
So my car suffered the dreaded glycol contamination. I had the dealer replace the original leaking Valeo trans with a Behr and perfrom a tranny filter replacement and fluid replacement. This cured the symptoms for about 2 months, but now the symptoms are back and the dealer says the transmission and torque converter need to be replaced. They quote $5600 for the job using a Mercedes-rebuilt transmission and new TC; the list price for the trans is $2500 and the TC is $1500 (!).
I called every independent shop in the area and got quotes ranging from $4300 to $8000. I searched online and found similar pricing for rebuilt transmissions and rebuilt torque converters for $300. Performance rebuilds are a little higher at around $4300, but I am pretty sure the original trans is adequate for moderate performance upgrades.
Is replacing this transmission possible as a DIY? I have access to a lift and transmission jack and all the normal tools. Do I need any specialty tools or methods? I am willing to buy a factory service manual if someone can point me toward a source. I replaced the transmission in my '70 Nova, '86 Monte Carlo SS and '88 Vette without incident; is this little Merc much more difficult?
TL;DR: Can I replace the transmission in my C32 myself?
Thanx!
Thanx!
03 g35 coupe...........02 c32 Sold
if you have experience replacing the transmission in those other cars, you should have no problem replacing the transmission on the c32. When you subtract the electronic components of the c32, its basically the same as any other car mechanically.
You can get a one day subscription to Star
data and copy the wis procedure.
You might want to contact
http://www.silverstartransmission.com/Transmission.html
and get a quote low 2grand for most 722.6
Pm me if you need a shop in the south end that a good friend has at a house down that way and he is a senior tech.
Sorry to hear of your loss.
IPT has the high stall .5-1 second quicker converter for 699
and his bullet proof valve modified nag1/722.6 trans for mid 4 grand.
Rated to 800 hp you will never have another issue
02 C32
Speaking of the electronic components, do you know if there will be any electronic challenges with swapping the trans and TC or if it is plug-and-play? Does it have to be hooked to a computer to make the new transmission play nice with the old TCU/ECU/who-knows-what-else?
Thanx for the reply!
02 C32
Rated to 800 hp you will never have another issue![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Holy cats, thanx extra for the link to Silverstar transmissions. Sounds like a good company with good prices, making me think this might not be such a crushing expense after all.
02 C32
Just to update: the good folks over on the non-AMG W203 forum also seem to think this swap is pretty straightforward mechanically, but will require having the DAS computer to perform a relearn/adaptation procedure. If I do the swap myself, I am hoping the car can be driven to the dealership to perform that relearn rather than having to tow it. If anybody can comment on that I would appreciate it, and thanks again to all who have given such good advice!
