C32 Wheel Help?
Old Feb 13, 2011 | 11:25 AM
Piraya33's Avatar
2004 C32 AMG
Question C32 Wheel Help?
Hey guys, I have a problem. I just found out that my front passenger wheel has a crack in it and the tire has a bubble. I guess I'm just going to replace all the wheels and tires because these are knock-off ebay wheels that are on it. My question is, what OEM mercedes wheels will fit on a C32? I am finding wheels all over craigslist, but I am not sure if they will fit my car. I know the easiest way to find out is to take my car with me, but I can't because of the cracked rim. Thanks for any help!
Old Feb 13, 2011 | 11:35 AM
Piraya33's Avatar
2004 C32 AMG
I found some 18" OEM wheels from an S-class AMG. Will these work? 18x9 front and 18x9.5 rear.
Old Feb 13, 2011 | 11:37 AM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
I'm not a fan of aftermarket wheels because you may need spacers. Same goes for the E-class and S-class wheels you may see on ebay and the classified. I bought a nice pair of OEM 18's from a CLK55 and they fit great.
Basically, stock C32's, stock W203 (2004.5 and newer), C55, CLK55 wheels are all plug and play.
There are some good deals out there. I'm afraid you may not have the time to shop for them though.
Good luck.
Old Feb 13, 2011 | 11:38 AM
ScottW911's Avatar
No. You will regret that.
Old Feb 13, 2011 | 02:59 PM
Piraya33's Avatar
2004 C32 AMG
Will any of the new C-class wheels fit? Like C63 or C350 etc...?
Old Feb 13, 2011 | 07:25 PM
chris.bachman's Avatar
a car.
I just put the C63 replicas from powerwheelspro on my C32 this weekend and they fit fine without any spacers. They are 8.5 all the way around though so you'll lose the staggered setup. Take a look in the picture thread to see them.
Old Feb 13, 2011 | 07:39 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
I think the new C-class is M14 bolt size and the offsets are slightly different, you may need spacers.
Old Feb 13, 2011 | 08:32 PM
Piraya33's Avatar
2004 C32 AMG
Chris, those wheels look awesome on your car! What size did you go with? How can I find where you got them from?
Old Feb 13, 2011 | 09:11 PM
Piraya33's Avatar
2004 C32 AMG
Nevermind, I found them. The website says that they require spacers to fit the AMG brakes. Did you have to use spacers on yours?
Old Feb 13, 2011 | 09:21 PM
a car.
I had spacers on but took them off and they clear just fine. You will need shorter lug bolts though. 28mm-30mm are fine.
Old Feb 13, 2011 | 09:35 PM
Piraya33's Avatar
2004 C32 AMG
Any noticeable difference going from staggered to non-staggered setup?
Old Feb 13, 2011 | 09:39 PM
a car.
I read that aside from the look, there really is no benefit to having staggered wheels. I haven't been able to put the car through its paces since mounting them but some spirited highway driving felt good.
Old Feb 13, 2011 | 09:43 PM
Piraya33's Avatar
2004 C32 AMG
What size tires did you go with? I have 19's on my car now and I feel EVERYTHING on the road because my tires are so slim.
Old Feb 13, 2011 | 09:58 PM
a car.
Check your PM Piraya.
Old Feb 15, 2011 | 05:12 PM
gtr886's Avatar
E63 W211 08, C32 W203 02
I saw ur wheels on powerwheelspro.com but they noted that you need spacer for AMG breakes?
Old Feb 15, 2011 | 05:25 PM
a car.
I had 3mm spacers and the wheels stuck out a little to far so I took them off and they clear the caliper just fine.
Old Feb 15, 2011 | 07:45 PM
gtr886's Avatar
Did you get the AMG style 814? Do you need special lug bolts from their site?
The AMG 814 fits without spacer on the c32?
Old Feb 15, 2011 | 07:59 PM
a car.
I did get the 814's. I wrapped them in 265/35R18 but would recommend going with 255 just to be safe. You will need 12x1.5mm ball set lugs with a shank no longer than 30mm and no shorter than 28mm for the rear if you're not running spacers. I would recommend using the same bolts up front.
Old Feb 15, 2011 | 10:55 PM
reflex92's Avatar
02 C32 AMG, 2012 S550
I will add some food for thought because I have had a wheel NIGHTMARE!! with my C32. So when I bought the car the guy had an aftermarket setup with 19's and 5mm spacers. The car had shake steering wheel AND pedal shake at 50+mph. So I took it to discount tire hoping that the wheels just needed rebalancing etc. Nope they couldn't correct the problem and obviously told me to take it to Mercedes dealer. I took it to the dealer and they came back saying it was my wheels and the spacers and there was NOTHING they could do about it. Needless to say I decided to buy all NEW wheels and tires.
I found a set of stock, used 2004 CLK AMG 18's for like $800. I asked this forum if they would fit and even called Mercedes to clarify before I shelled out the cash, because we all know once you buy from craigslist you rarely can go back. Everyone said ok.....got the rims and they hit the spring housing and DIDN'T FIT!!!! I was SOOO pissed!
So I bought some replicas that STATED they were stock spec and NEEDED NO spacers (which is why I bought them) I put them on the car and they are SOOO close to the front calipers that you literally can't fit a piece of paper between them. Was driving down the highway yesterday and all of a sudden got a loud knocking noise.....car is now at the dealership waiting the verdict on WTF is going on. The knocking noise was an obvious wheel issue because it knocked with the rotation of the tires. But I know the wheels fit because I was driving it for a week before this happened with the new rims.
Needless to say wheels for the C32 have been a PAIN in my A$$ BIG TIME!!! This forum needs a thread for C32's that list a handful of rims that will fit the C32 AMG with NO spacers......just food for thought...
Old Feb 16, 2011 | 01:14 AM
gtr886's Avatar
wait, just to clarify.. you need different bolts(12x1.5mm 30mm) for the rear(w/no spacer) and the front (no Spacer) with stock bolts?
How did your C63 rep with a 35 offset to clear the c32 caliper without spacer?
Old Feb 16, 2011 | 08:10 AM
a car.
Let me start from the beginning to try and explain this and clear up any confusion.
I ordered the AMG Style 814 (C63 Replicas) from Power Wheels Pro. I got a deal on some 265/35R18 tires so I bought them and gave it a try. The 265/35R18 Falken Azenis tires fit perfectly with no bulge, however I can't say anything about ANY OTHER TIRES. The wheels are 8.5" all the way around and barely clear the spring perch up front. Originally I had 5mm spacers in the rear and 3mm spacers in the front. The problems I ran into are as follows;
Stock lug bolts are WAAAAAY to long for the rear. You will hit the e-brake sensor/assembly if you use them. It will do damage to both the bolts and e-brake components. Without a spacer in the rear you need to find 12x1.5mm ball seat lug bolts with a shank between 28mm and 31mm. Do not cut your stock lug bolts because they are not threaded the entire length of the shank.
The 3mm spacers up front were used to clear the calipers. It made the wheel and tire stick out to far for my liking. I measured the distance from the inside of the wheel to the front of the caliper and had around 5mm of clearance. I took off the 3mm spacer and if you're doing the math, that left me with about 2mm of clearance from the caliper to the wheel. I know the website says you will need spacers up front to clear the calipers on a W203 with AMG brakes. I suspect they are being cautious because it is a pretty close fit without them.
I wouldn't recommend using stock lug bolts up front, even though they don't hit anything when torqued down there is no enough thread staying inside the hub. Stock shank length is 39.5mm and only half of that is threaded.
So to sum it up you do not need spacers up front to clear the calipers on a 2004 C32 AMG, you WILL need shorter 12x1.5mm ball seat lug bolts for the rear (28mm-31mm), I would highly recommend shorter lug bolts for the front as well (same size), and if you want the widest tires possible, a 265/35R18 will fit.
I hope this helps you out.
Old Feb 16, 2011 | 01:02 PM
sterlingc1975's Avatar
2009 Porsche turbo, 2011 Porsche gt3(Luv) 2008 clk black- RIP 2003 Honda Element (Fav)
Smile
I just purchased these wheels and they are HUB centric no hub rings or spacer needed. My car is slammed and doesn't rub anywhere..
http://www.flickr.com/photos/33603812@N03/5449268761/http://www.flickr.com/photos/33603812@N03/5449268761/ by http://www.flickr.com/people/33603812@N03/, on Flickr
