185mm Pulley kit install help
Old Feb 13, 2011 | 07:21 PM
doom239's Avatar
2002 C32 AMG
I am in the process of changing out my Crank pulley,
So far I got everything off But I ran into a snag.
The bolt that was included with the kit dose not fit inside the new pulley is this supposed to be like this?
also I have this very small pulley And i dont know which one that is suppose to replace can anyone show me.
Thanks again guys
Old Feb 13, 2011 | 08:00 PM
loudandheard's Avatar
C32/C55 AMG
Check out this thread, there are a few links in the thread that go in to detail.
https://mbworld.org/forums/c32-amg-c...-pictures.html
Is the bolt oem, if so it should fit. Maybe you were given the wrong crank pulley bolt.
Old Feb 13, 2011 | 08:08 PM
doom239's Avatar
2002 C32 AMG
I tryed both bolts they seem to be the same size I will upload a picture of the bolts
I found out where the other pulley gose.
Old Feb 13, 2011 | 08:16 PM
C32/C55 AMG
Here's an old pic of my pulley and if you look at the left hand side you can see the crank pulley bolts in the bag.
Old Feb 13, 2011 | 08:17 PM
doom239's Avatar
2002 C32 AMG
Here are the pictures
They seem to have the same #
Old Feb 13, 2011 | 08:36 PM
C32/C55 AMG
They look to be the same bolts as the ones that I used. Could you post a pic of your pulley. Who did you purchase it from?
Old Feb 13, 2011 | 08:53 PM
doom239's Avatar
2002 C32 AMG
Here is the picture of the pulley the pulley is a 185mm ASP from Jerry
I figerd it out, you must remove the six bolts that are holding down the pulley to the dampener
the dampeners hole is a bit larger then the pulleys hole (idk why it would) be but it fit like a charm.
Thanks agaiin
I am getting my remote tune in 2 hours Then gonna go burn some tires LoL
Now How the hell am I going to tighten this bolt with out the Special tool LOL
Old Feb 13, 2011 | 09:45 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Thanks agaiin
time out...you did what??????
Please tell me you didn't take the pulley apart.......
The bolt fits perfectly in the hole. Twist it a little and it goes right in. Its designed that way....
Old Feb 17, 2011 | 09:20 AM
johnng117's Avatar
2002 C32 AMG
I'm also having this problem, the bolt simply doesn't fit..
Old Feb 17, 2011 | 09:49 AM
c32used's Avatar
LET C32 2002
Exclamation
Guys/gals installing any type of pulley one should really be having a trusted certified mechanic who has knowledge in this
Old Feb 17, 2011 | 11:00 AM
doom239's Avatar
2002 C32 AMG
I took mine apart being very careful. dont do what I did Jerry Said it was a big No No
Old Feb 17, 2011 | 11:33 AM
jturkel's Avatar
02 C32 AMG
...you aren't supposed to take them apart. they are specially balanced and IIRC, taking them apart messes this up
Old Feb 17, 2011 | 06:46 PM
Newzchspy's Avatar
PLAID
I dunno Vic, I did my Code 3 all by myself??
Old Feb 17, 2011 | 09:26 PM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
I did 185MM install twice without any issues, but it was a PAI... Had previous experience with ASP on M111K.
What's this about the bolt not fitting??? People when a bolt seems to not fit you don't take apart your pulley. Call Eurocharged for further instructions or a new bolt...
