C32 - Pulley & ECU Mod & Heat Exchanger (Eurocharged) - Arrived today :)
Cant wait to install the Heat Exchanger and Pulley... My car engine is original.
Suspension: PSS9 + Eibach Swaybars front and rear.
Hope i feel the extra power.... and installation is smooth.
Update later......
....and i drive hard
Add Tirerack.com to your Favorites list.
I did all of my mods at once, except the heat exchanger which was later, but you will certainly feel the difference in power.
It took me quite a bit of time to install the HE. My EC HE for some reason has different mounting points than the DIY available.
Let us know!
naw. i'll call more ladies! (0-34 seconds: http://www.youtube.com/watch?v=PfcYr1xPDsE)
lol, but for my test, more than four hours (priapism) is bad haha.
oh yah....how could i forget lol.
The damned seat heater is more of an issue than running a 181/185 or Code 3
Let us know!
My Exchanger is not a direct bolt on too, i'm in the middle of modifying the mounting bracket. head spinning
to ensure that the HE is securely attached to the support. I used aluminum bars to create stronger attachment between the mounting tabs and radiator support.It might be different for you though, but good luck and the end result is worth it!
The frozen boost heat exchanger I used cost $5 for the brackets and took an hour to make.
If I was to go back would have got the 26x7x3.5 for like $20 more. Still less than $200 dollars...
Too bad HPAutowerks didnt keep making the Code 3 stuff, Brandon had some decent product when he was in the business!!
The car has changed from quick to very quick, feels a lot lighter and the throttle response is perfect now (press and go)! Very very happy.....
Had to change the alternator too as mine was on the way out.
I guess my tires wear will increase...
Update later......
