anyone have Yellow DPS Coilovers?
http://cgi.ebay.com/ebaymotors/YELLO...Q5fAccessories
They seem to be a solid coilover kit, 33-level dampening adjustment, and front camber plates built in. The setup has separate height and pre-load adjustments. Spring rates are 6kg front, 14kg rear.
I know for an extra $100 I can get H&R Coilover kit (these do not come with the camber plates up front).
Im not trying to start a discussion about what coilover kit is best...coilover kit A vs. coilover kit B...I know there are a lot of proven coil kits from H&R, KW, PSS, etc. I just want some solid, constructive feedback from anyone that ACTUALLY HAS first hand experience with the Yellow DPS kit on their C32 or any other car...
http://m.evolutionm.net/showthread.php?t=534182
Now the most important thing you should be concern about is safety. The front suspension relies on your coil overs hold up your car, if it breaks off, there is no more steering, no more control. Very bad...... be careful. Spend more money and get something that has proven to be safe and good
