Best power steering fluid?
Old Mar 26, 2011 | 06:37 PM
KniteOwl's Avatar
02 C32 AMG
Picked up power steering fluid for top-up from the dealer today. They insisted that A 001 989 24 03 (conforming to MB 345.0, green like Pentosin) was the right thing. But it seems like my c32 has the brown MB 236.3 (A 000 989 8803) in it. Had to top it up to quiet down the PS pump, so now I will have to flush it - the original fluid is really dirty anyway. But which one is better to fill it up with?
Heard a lot of praise for the Pentosin - quiet when cold, has a 40 deg C higher temp rating etc, but is there something else I should know? It seems that only the colder climates get the Pentosin as OE fluid. Average summer day temp where I live is rather high, like in the 30's C / 90's F, and we rarely drop below 0C. Any advice?
Old Mar 26, 2011 | 07:09 PM
sknight's Avatar
c200k
If it's red, it might be pentosin 11s, but not sure. At least on my car, the OEM stuff is Pentosin. Check the chart.
Old Mar 27, 2011 | 07:44 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
I’d suggest using the recommended 345.0-specification Pentosin CHF 11S fluid.
reference
Old Mar 27, 2011 | 11:24 PM
loudandheard's Avatar
C32/C55 AMG
reference
That's what I used. Here it is on ebay http://cgi.ebay.com/ebaymotors/PENTO...Q5fAccessories
Old Mar 28, 2011 | 02:41 PM
KniteOwl's Avatar
02 C32 AMG
Thanks a stack for the replies. Pentosin it shall be then. The current fluid lasted 9 years, and the Pentosin can only be better.
Old Mar 28, 2011 | 02:51 PM
sknight's Avatar
c200k
I think you're missing it- Pentosin is a brand. They make a multitude of oils. For the Zentralhydraulikfluessigkeit (CHF), there are two main types- 7.1 (the common green one) and 11s, the red synth one. Choose correctly because, going back a couple decades now, most manufacturers don't advise changing, even if it's the intuitive "upgrade" to 11s from 7.1.
Old Mar 28, 2011 | 03:09 PM
KniteOwl's Avatar
02 C32 AMG
Thanks for the heads-up, sknight. This is what I intend to use: http://bevo.mercedes-benz.com/bevoli...nt_action=show. Should be safe.
