C32 Valve Cover Gasket
Mercedes C32 AMG
Are these the correct Gaskets? I've order parts for the C32 online only to get the wrong parts. Just want to make sure these are correct.
http://www.autohausaz.com/search/pro...Cover%20Gasket
Mercedes C32 AMG
Thanks everyone.
And Juan makes a good point. I'm not sure off hand what the tightening sequence is. I'll see if it's listed in All Data and if so I'll update.
C32/C55 AMG
See if you can do a photo diy if you can. I thought I had a serious leak, but I think it's just coming from one side of the valve covers.
Here's a diy for the m113 http://www.benzworld.org/forums/w210...er-gasket.html
Mercedes C32 AMG
Thanks Loundandheart
Also while I'm at it we're going to change out the spark plugs. I understand most here say the NGK's are the way to go but I try to keep everything as OEM as possible. (Not sure if the NGK's are OEM)
autohausaz lists the C32 OEM plugs as Boche 7407. Is this also correct?
http://www.autohausaz.com/search/pro...2@Spark%20Plug
Thanks Guys Can't wait to get this tune up done
Here's a thread from the crossfire guys. It seems like they are just doing the breather covers on top. It looks like you might be talking about the covers under the coil packs. Good info any way. They say the bolts are one use bolts and shouldn't be reused because they break easy.
http://www.crossfireforum.org/forum/...over-leak.html
Mercedes C32 AMG
Now that's good to know. And yes we are taking the covers off underneath the coil packs. I wasn't aware the bolts needed to be changed out, good to know. Any place online I can pick up the bolts?
The part number is in that thread (for the top cover bolts). They sourced them from MB and said they were only 2.50 a piece or something. Parts.com would probably have them.
Mercedes C32 AMG
Thanks I'll order those in. What I'm wondering though, is if the bolts for the cover under the coil packs are one time use also.
