ANYONE add STRUT TOWER BRACE?
FYI, I wouldn't trust that they say it fits the C32 though. I remember when I got one for my BMW, it said fitment was for 318, yet when I received it, I had to relocate my coilpacks to make it fit. Later that year I sold it to a guy with a 325 and he had even more issues with stuff in the way, WTF? Just beware.
That being said, thanks Mike for touching base. If anyone is local to us, please contact me and we can setup a time to look over the car. I would probably want a couple models just to make sure there are common denominators between a C32 and a C320, for example to make this work across multiple W203's. You can checkout our new Performance Center in progress, and I may even take you for a ride in one of the 600hp CLK Black Series if you can make it in early next week
so we r all on the same page, the w203 has a limp front end, this brace will make the front end a rigid platform so the suspension CAN do what it is intended to do- turn corners as sharply as possible while keeping the tires from being ground off. for those w sway bars , coil overs, sticky tires (.ie michelin ps2), will find that these performance parts will work much better when attached to a rigid structure that keeps the entire suspension SYSTEM in ideal geometry will under lateral g forces,,,,tires will also last longer as max contact patch will be maintained so there will be less scrubbing ,,,,,,,,,,,,,,,,,WIN WIN ,,,remember happiness IS the next corner! thanx, mike
Not a bad nostradamus moment there.https://mbworld.org/forums/sl55-amg-...-business.html
http://jalopnik.com/5792464/mercedes...nds-of-dollars
