Dyno (H&S+BMC+RENNtech pulley)
Old May 16, 2003 | 01:25 PM
Pierre32///AMG's Avatar
Porsche Turbo Stage 4, Cayenne S ... gone C43, C32, ML55 & Ducati 999.
https://mbworld.org/forums/showthrea...0&pagenumber=2
Old May 16, 2003 | 02:44 PM
well my outcome with H&S Chip+BMC Filter+RENNtech pulley= 40-43HP and 50-53 ft.lbs of TQ (at the wheels values), with no headers and IC upgrade yet.
Old May 16, 2003 | 04:21 PM
SiLvaC32's Avatar
C32
wow... thats some impressive #! if you don't mind... how much have you spent?
Jerry
Old May 16, 2003 | 05:39 PM
Jerry
H&S Chiptunning:
US$ 1,290 with shipping to Germany and return.
BMC filters:
US$ 150 (the two filters and shipping from Italy).
RENNtech pulleys
US$ 1,995 (pulleys and 2 RENNtech filters).
Total: $ 3,435, like the same that the RENNtech kit(ECU+Pulleys)
I have not installed the RENNtech filters I am using the BMC, and I have not installed the SL55 Y-Pipe either ($85+tax).
Summaring, for me the best $/hp is go with H&S+BMC= $1,444, and even more if you are at sea level, 0 fts elevation. Or go just with ODPS EVO's kit that is good too $1,690.
Next, either way get the RENNtech pulleys, as I did, or simply buy the RENNtech kit(ECU+Pulleys) as a first move $3,495.
Old May 16, 2003 | 08:02 PM
SiLvaC32's Avatar
C32
basically the same price as EVOSPORT's upgrade "ODP + header + chip" and the same results right?
Jerry
Old May 16, 2003 | 08:52 PM
Mach430's Avatar
No. Our pulleys will gain more at the same octane. Bverroti gained 45hp at the wheels on 98 octane, where on 91 we only get 30.
Old May 16, 2003 | 09:06 PM
Vadim @ evosport's Avatar
C32 AMG
PierreC32: Good info.
I do have one concern. Your last run, 007 - blue one, looks like the engine has detonation/missfire. At 5300 rpm it is pretty severe - about 20 ft.lbs. drop.
Looks like you do not have enough octane for the timing curve H&S is running. The wavy line is due to knock sensor pulling timing out. Look how smooth run 003 is.
Old May 16, 2003 | 10:55 PM
I do believe Vadim that you are right, other wise between 5,300 and 6,200 I will get huge improvement. Also, I can send you all my Dyno files, here is another interesting chart: Air Fuel Ratio.
http://groups.msn.com/Mercedes2003C3...oto&PhotoID=30
One think that I am going to try to do is change the air filters, for the RENNtech ones, or even the stock one; because perhaps, I will get less pulling timing out with less air.....what do you think Vadim?
Old May 16, 2003 | 11:33 PM
SiLvaC32's Avatar
C32
oops... i didn't know that he was using 98 octane...
Jerry
Old May 17, 2003 | 12:17 AM
Jerry
Jerry, I am using 91 octane the point is that if I would have used 92-93 I will get better outcome, as Vadim mentioned becasue the H&S timing curve works better under higher octane under bigger pulleys configuration, this is the leason learned here. Nevertheless, the result still been competitive but it needs little be adjusted.
Old May 19, 2003 | 01:22 AM
C32 AMG
PierreC32: Yes, you are detonating. As you can see the new graph (blue) is significantly richer - mid11s vs. mid12s. DME is trying richer mixture to prevent detonation.
See if you can locate Unocal 76 station in CO. Some sell 100 octane. Try runing half 91 and half 100 for a about a 100 miles and redyno again. You could see as much as 20HP. Good Luck!
Old May 19, 2003 | 03:41 AM
Mach430's Avatar
Pierre,
Until you are able to fix your a/f ratio, you should baby your engine. You need to find a permanent solution to your engine detonating. In a short while, semi-hard driving can leave permanent effects on your engine. Not to toot our own horn, but this is why we design our mods to run safely on 91 octane...
Good luck!
Ben
