Alarm system
Old 05-06-2011, 04:56 AM
spatton's Avatar
2004 C32 AMG - 2009 C300 Sport
Alarm system
im sorry if this was posted before i did a search but i couldnt really find what i was looking for. I understand that the siren doesnt chirp because of the netherland setting, but when i lock the car and open the door through the window the lights flash but i am still able to start the car...is the smartkey turning off the alarm? is the horn shot or is the alarm module toast? do i even have an alarm system? where is the alarm module maybe it is unplugged? I will check the horn tomorrow when i get some time to take the wheel off. Any help would be greatly appreciated.....also panic does not work
Old 05-06-2011, 09:58 AM
loudandheard's Avatar
C32/C55 AMG
This has been my problem for a long time. I had the alarm siren replaced twice and then I replaced it myself with the latest model. For some reason when I installed it, I still didn't get my siren to come one.
When my alarm siren kind of worked, the alarm would go off by itself and the lights would flash to the point that it would drain my battery. Now I don't have that problem, but the siren doesn't even come on.
Old 05-06-2011, 10:13 AM
thtguy's Avatar
2017 GLS 550
more than likely the battery in your alarm horn is dead. You need to replace the siren. Your alarm siren, I believe is under the splash shield where your windshield wipers are.
Old 05-07-2011, 07:11 AM
Budget Baller's Avatar
Mercedes C32 AMG
I know my alarm works but it's so quite it's not even worth it. I swear it's almost funny how quite it is.
But it does indeed sound like your Alarm may need replaced.
Old 05-08-2011, 02:50 AM
spatton's Avatar
yea i guess i will head to the dealer i have a check engine and abs light on as well... hopefully those 2 are nothing major they probably are not but i really would like my alarm to work lol
Old 05-08-2011, 02:51 AM
spatton's Avatar
is it not above the front wheel on passenger side towards the rear?
Old 05-08-2011, 10:32 AM
C32/C55 AMG
That's where mine was. I had to take off the passenger side front wheel and then you should be able to remove a section of the fender lining to get access to the horn. If I remember correctly, it required the use of a security torx socket, but I can't recall what size.
Old 05-08-2011, 03:52 PM
spatton's Avatar
where might i find a replacement horn to buy besides stealer?
Old 05-09-2011, 09:34 AM
thtguy's Avatar
2017 GLS 550
Sorry I was thinking about the SLK, had to replace my wife's and it was a PITA to get to.
Old 05-17-2011, 09:48 PM
spatton's Avatar
just replaced my alarm horn from parts.com...works great...easy to put on... my car even chirps now when I lock and unlock!
Quick Reply: Alarm system
