engine swap-c55 to e55
Old 05-20-2011, 10:36 AM
cab_5150's Avatar
2006 e55,2014 e350,81' vw rabbit diesel p/u,
i know this i sa much debaited subject. but i need your guys help.
i justed pick of a smokn deal on a 2005 c55 with 75k miles.
i was also given a great deal from a buddy on an e55 motor.
i want to swap them.i know the transmissions are the same.and the motor will drop right in no problem.
my questionb is with the ME. can i use the stock c55 or buy a new one for the e55 motor. map. vs maf concern.
if i used the c55, how to change so it see the two map sensor on the intake tubes of the e55, verse the maf sensor on the c55.
any ideas on what im missing?
thanks chris
Old 05-20-2011, 12:57 PM
Newzchspy's Avatar
PLAID
thanks chris
Is this a NA E55 engine or the SC'd one??
Old 05-20-2011, 01:02 PM
Dingleberry's Avatar
Marsaydees
he's talking about map vs maf
SC obviously!!!!!111eleven
Old 05-20-2011, 01:26 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Contact Sunil on this forum:
W203 with E55 Motor
http://youtu.be/qRjm2Pk0fvQ
Old 05-20-2011, 01:58 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
finally some action!
Old 05-20-2011, 02:18 PM
Newzchspy's Avatar
PLAID
Originally Posted by Gramma_Benz
Or Mike (HooleyBoy) can give you a LOT of insight as well since he did it recently..................There's a TON of threads on what Mike (Hooley) did on his car about 2 years ago.
Old 05-20-2011, 03:24 PM
Quicktwinturbo's Avatar
CLS, SLK, ETC
It's not easy as installing a type R in to a civic but it has been done..
IMO, it's just better to go with the kleemann or buy E55..
Didn't hooley just installed a SC from an e55 engine? Didn't know he swapped the motor..?
Old 05-20-2011, 05:01 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
You are right but the ECU and MAF vs. MAP issues are the same.
Old 05-20-2011, 05:57 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
I would say try contacting hooleyboy however its like the guy has plain disappeared
Old 05-20-2011, 10:03 PM
loudandheard's Avatar
C32/C55 AMG
If you do the engine swap you will need an E55 ECU, EIS, wiring harness, and possibly a new key. If you can get all that from the other car, you're golden.
Old 05-20-2011, 10:22 PM
c32used's Avatar
LET C32 2002
yes just the SC but at one point I think he replaced the engine to
Old 05-20-2011, 10:39 PM
320 dreamer's Avatar
2003 porsche 996 turbo
contact rcompart and get out your checkbook. he is the guy who transplants the s/c v8 into the crossfires. key start and all the electrics can be done by him as well as the mechanical installs.
Old 05-21-2011, 12:59 AM
559EVO's Avatar
2005 C55
Not worth all the money invololved, I'd say get an E55 instead.
Old 05-21-2011, 01:28 AM
whipplem104's Avatar
1990 300ce supercharged and intercooled
As said, the physical swap is pretty easy. Have to add the heat exchanger and intercooler pump and plumbing. Contact Accelerated industries. He can help with the ecu. Get a used 55k ecu and have it unlocked and recode it to your car. This can be done without braking the bank.
Old 05-21-2011, 08:39 AM
V12Godspeed's Avatar
Your worst nightmare...
thanks chris
Where are you located? I have someone who did this swap and could probably do yours...all the wiring and Electronics part of the swap was done by my tech. Speedriven drop the motor in the bay and is doing the Tunin for this monster, LM 24 out in long island did all the manifolds and piping, turbo allocations, oil pumps.
https://mbworld.org/forums/w211-amg/373559-ev12-9.html
Old 05-23-2011, 06:37 AM
EVOII_Racer's Avatar
Mercedes Evo II
Thumbs up
This is actually my next project within the next 4 months when I will purchase another C55.
I will transplant an E55K engine which will be tuned on top. (Expecting around 600hp) The price is expensive but well worth it IMO. You get an extremely reliable car much better than the Kleemann version since the C55 engine was not designed for a Kompressor.
However, I will also install the entire rear axle with the LSD from the E55K. The work will be done by Vath in Germany.
Old 05-23-2011, 06:41 AM
Mercedes Evo II
IMO, the point to tune the C55 instead is because you will get a better handling car than the E55. Much lighter and also faster so it could be worth the price. At least for me it makes sense since I really like the C55
Old 05-23-2011, 10:38 AM
MBfinatic's Avatar
e36 318i, 2004 sti
Well put I think the C55 in the end has a lot more potential.
Old 05-23-2011, 12:02 PM
mikekuriger's Avatar
2010 C63
BTW, the transmissions are not the same. Your C55 tranny will not be able to shift under the torque of the SC. there are options such as swapping out the solenoids and TCU tune but ultimately it will not last.
Old 05-23-2011, 11:19 PM
JonMBZ's Avatar
06 C55, 09 E350
That was AMGSC
Old 05-24-2011, 06:37 AM
Mercedes Evo II
Yup good point.
At first I thought it was the same transmission but it's not. Would you happen to know the difference? Is it just stronger on the E55 simply?
In my case I will transplant the engine, the transmission and the entire rear axle. I believe the E55K as a special Limited Slip Differential correct?
Old 05-24-2011, 07:22 PM
msheredy's Avatar
MB
+1
Old 05-25-2011, 09:45 PM
BrandonS's Avatar
'05 C55
Talk to Hooleyboy as well about the transmission. He has modded the stock transmission tune. He claims it will hold up to 600hp with his tune and the blue solenoids.
Old 09-25-2011, 11:57 PM
LantanaML320's Avatar
2004 Chrysler Crossfire
This is a great swap and can be done. I wouldn't change the trans. you just need to add the engine and assocaited parts such as heat exchanger, and pump. You would want to use the harness from a 55K engine and also a 55K ECU. the ECU can be unlocked and programed to the car with SDS in developer mode.
Old 09-26-2011, 08:54 AM
C32/C55 AMG
I may do this to my wife's C55 in the future when she gets a new car, but now I am.not allowed to even paint the grill.
Quick Reply: engine swap-c55 to e55
