Changing tires
Old May 25, 2003 | 02:18 PM
eyuan23's Avatar
asdf
Changing tires
Curious if anyone has ever just changed the rear tires. The front ones on mine have little wear but the rear definitely needs changing. OK to just change the rear???
Also, anyone know of good prices for tires and recommendations on brand? I currently have P-Zero Rosso. Thanks in advance guys!!!
Old May 26, 2003 | 01:44 PM
C320_Avantgarde's Avatar
The new P Zero Neros are good - so is the Dunlop SP9000
Old May 26, 2003 | 04:15 PM
pc527's Avatar
2005 B6 S4
Re: Changing tires
I would suggest the Potenza S-03 Pole Position.
Heard lots of good things about them.
I currently have the Dunlop SP9000, don't like them, they last long but no traction.
peter
Old May 26, 2003 | 04:36 PM
NT WORK's Avatar
C32
Tires...
Fine to change the rear tires by themselves.
I've had both the Dunlop SP Sport 9000's and the Bridgstone S03 Pole Positions and they are worlds apart.
If you like doing burn outs, get the Dunlops - they seem to spin easy.
If you like to corner fast and want absolute grip (like me) - the S03's are WAY better. These tires are much harder to break, which = more traction, which = you can push the car much harder into corners with control.
Also the S03's are very quiet in the corners, where as the SP Sport 9000s squealed more. For a comparison, the stock Michelin Sports just scream like a biaaatch under the same hard cornering.
My .02 - S03's.
Old May 27, 2003 | 11:01 AM
Zeppelin's Avatar
C32
If you are keeping the fronts- P Zero Rosso's then I would only use the same on the rear. Otherwise change all four.
Old May 27, 2003 | 07:20 PM
eyuan23's Avatar
asdf
Thanks for everyone's input .
I really like the Bridgestone Potenza S-03's, but I think I am just going to change the rears with P Zero Rosso's for now. Guessing I'll need to change all 4 next year. This is just to save money for the time being so I don't have 2 half used front tires just sitting around. I do mostly normal driving anyways. But I will definintely look into better tires later.
Thanks again!
