bigger tires for rear C55
Old Jun 17, 2011 | 09:10 PM
aussie e55's Avatar
2009 C 63
Smile bigger tires for rear C55
hi
looking at larger tires for rear any problems abs/speedo/rubbing vehicle is standard not lowered & original factory wheels what size can i go to ? thanks.
Old Jun 17, 2011 | 09:24 PM
chris.bachman's Avatar
a car.
I've got 265 in the rear on my C32 using a 35 offset wheel and no rubbing at all.
Old Jun 17, 2011 | 11:42 PM
aussie e55's Avatar
2009 C 63
Question
thanks chris
does anyone know the offset of the standard 18 inch C55 rear wheel thanks.
Old Jun 18, 2011 | 12:26 AM
PC Valkyrie's Avatar
C55 AMG, 135i, 911 GT3, GLE43 AMG
Originally Posted by aussie e55
thanks chris
The offset of the stock C55 AMG rear 8.5" x 18" rim is 34.
The offset of the stock C55 AMG front 7.5" x 18" rim is 30.
Old Jun 18, 2011 | 12:41 AM
aussie e55's Avatar
2009 C 63
Smile
thanks val. great site.
Old Jun 18, 2011 | 01:34 AM
pww's Avatar
pww
'05 C55 AMG
Chris I'm assuming that's a 9.5? Ever tried going to 275? I'm gonna be running that exact setup and want to be going up in tire size and am trying to see if 275 is possible.
Old Jun 18, 2011 | 02:27 AM
johnng117's Avatar
2002 C32 AMG
265 is fine, you might as well invest in better quality rubber than going to 275.
Old Jun 18, 2011 | 10:41 AM
a car.
I run 8.5 all around.
Old Jun 18, 2011 | 11:57 AM
johnng117's Avatar
2002 C32 AMG
i have a friend running 275 without rubbing problems, but in terms of grip nothing different.
I changed from Hanhook to Yok AD08 and its much better still on 265
Old Jun 18, 2011 | 01:32 PM
kent426's Avatar
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
275 will require inner fender trimming and rolling. there is only a 2/10 difference in width. Does it matter to me? Yes, there still is not enough tire in the rear to allow full power out of low speed corners.
Old Jun 18, 2011 | 03:59 PM
pww's Avatar
pww
'05 C55 AMG
What offset are you running?
Old Jun 18, 2011 | 11:19 PM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
Good luck on that, you can't even do that with a Corvette with 305s in the back.
Old Jun 20, 2011 | 10:51 AM
kent426's Avatar
33 ET
