VSS (variable speed sensor) wire diagram!? NEED HELP!!!
Can anyone please help!?
thanks!
"[add an additional speed pulse coming out of the rightside doorsill (connect to a unused ended green with black line wire)
In the passenger kickpanel there should be a green with black wire which is unused.
The speed sensor is indeed hooked up from the single unused wire in the passenger kick panel.]"
Good Luck
