C32 Center Oval Vent on Dash
Old Aug 1, 2011 | 02:46 PM
AMG_Guy's Avatar
CLS55
The vent in the center on top of the dash, in my 2002 it had a dial on the dash. I've seen on a 2003 it does not have the dial.
Is there a reason for this?
Old Aug 1, 2011 | 07:27 PM
Mr.Benzo's Avatar
02 C32 AMG, 06 C230 Sport (Gone)
The dial alters how much air diverted to flow out that vent you run the ac. If it is turned all the way down more air flows out through the other air vents and vice verse
Old Aug 1, 2011 | 08:35 PM
francoisisp's Avatar
AMG
not saying you are wrong but i thoguth it was to regulate outside air you want in the system which if open all the way the faster you drive the harder it would blow when that valve is open, but it would not be a good idea to open it if you are trying to get heat going in the winter since cold outside air will not help with heatin
Old Aug 1, 2011 | 09:50 PM
loudandheard's Avatar
C32/C55 AMG
I think you are right about this. The dial was deleted after 2002 or 2003.
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
What he says. Opening the top vent just sends more air upwards instead of to the dash vents. No change in source. I added this to my '06.
Old Aug 1, 2011 | 09:56 PM
C32/C55 AMG
When I first got my car, there was an issue with the top vent. When it would rain and I would have a/c on, it would cause my windshield to fog up. Apparently they fixed it with an updated part when I took it in to get looked at a few years ago.
