Loosing power intermittently
Old Aug 15, 2011 | 06:23 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
I just replaced my IC pump with a CM30. This is my second CM30. But this time, after barely 100 miles, I started to experience the same situation where
after a 15 minute daytime cruising, I punch it (from 65 and up) and no response. But, I could still cruise even after, just can't produce a kickdown.
From a stop, the car crawls slowly ( even with a heavy foot on the throttle) and then gets going. I'm not sure if this would happen during a cold morning start. I still have to find out. My guess is TPS.
I've also recently changed coolant.
Old Aug 15, 2011 | 07:09 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Hey Doug,
pull some codes and see if there's any "hidden" codes stored that didn't produce a CEL. That will likely point you in the right direction.
Old Aug 15, 2011 | 07:31 PM
60n5pt1's Avatar
Thanks Greg, I knew you'd chime in eventually, lol. I know you had your throttle body remanufactured, how's that coming along?
I just disconnected the battery and will let it sit for awhile.
I also have vibration issues that come and go especially during my early morning commute (45-65). I think my car needs an general annual checkup
(Coolants, suspension, fluids, brakes,etc.).
L8TR
