Eurocharged AMG Speed Shift TCU Flash - $499
#151
Yeah I see it with all shifts...I've had mine for a couple weeks now so the TCU should have adapted by now. The car is bouncing off the revlimiter before shifting, it's not like it's losing traction either. Something must be wrong, I am contemplating going back to stock TCU
#152
It happens to me aswell when the car is warm. I wouldn't be driving aggresivly with a cold car. I'm going to try shifting again at like WOT and see what happens. It really doesn't feel like it should be there. Even one of my friends questioned what that was
#153
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
if your hitting like a pause or something sounds like a torque limitor...
thats usually what that is...
#154
Supercharged CLK500 & ML500
I have the TCU tune, but I haven't had a chance to go WOT (I live in Traffic all Day LA). I'm kind of hesitant to do it since everyone is reporting problems (subscribed to this thread now). My car is Kleemann Supercharged with a Kleemann ECU Tune, so I might have different results. I will report my findings on this thread.
#155
#156
Super Moderator
GMC - Miata - Trek - P-Car
Have never personally encountered that AFR phenomena during (wideband) logging while stock or modified.
My aftermarket tuner seems to have stumbled across a viable workaround.
#157
2003 porsche 996 turbo
who's your tuner and would he care to expand on this? i now have the v2 version form jerry but havent been able to install it and run it as i have intake parts at needswings for thermalcoating. from what jerry told me he found a file that needed adjustment to 6800 rpm and raised all the torque limiters to max. hopefully i can get the car out next week and datalogg the results
#158
Eurocharged.
Tuning the tcu to rev higher sounds unsafe. Do you recomend to strengthen the head before changing the rpm redline? Because I've had first hand experiance from over reving and blowing a head gasket and warping the head. What do you recomend?
#159
And I'm not running this 6800 RPM version on my car so I'm going to assume there is a second version.
Cdirtytwo, have you made your decision to go back to stock or are you keeping it?
Also, I have a question for Eurocharged. If the rev limiter were to be at the stock RPM, would there be this spike in AFR as described above? The best I can describe it is basically the feeling you get from the car when you hit a speed limiter. The car just stops pulling, then shifts. I haven't revved that high since this happend just in case it's not safe...
#160
SPONSOR
There's a TCU V2 version?
#162
Super Moderator
#164
so you just threw it out there to stir the pot? im asking straight up who your tuner is and what he has done to solve the problems. i could care less who started what thread. i have mods from virtually every sponser and custom modder on here. im no fanboy of anybody, i buy what works the best. i have e/c,ttm,speedriven,needswings and some custom parts on my car
#165
Super Moderator
“Stir the pot?” Hardly.
Simply stating the fact my experiences and results have differed from those of other participants in this tuning thread.
Good luck with your car and its modifications.
Disclosure: I have LET/Eurocharged hardware on my C.
#166
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Hey splinter, just to confirm. You do have an EC TCU tune but the ECU tune is from someone else?
#167
#169
What kind of performance increase are you seeing from this? What kind of increase in quarter mile times are we talking? This sounds great!
Wish you had some kind of special... I'd make the drive down to Chicago ASAP!
#171
Gramma, I think I still have torque limiters from what I am understanding from Jake. Eurocharged just raised them. When I do a pull in WOT, I hit the limiter and then it shifts gears. I'm thinking if I have an ECU tune it might fix this?
#172
Well I have an ECU tune to go with the TCU tune and my car still does it...
#173
nope ecu tune wont fix it. as soon as i get my in take parts back from needswings ill try the v2 version and hope it fixes the problems.
#174
Super Moderator
Almost certain you’ll understand it’s only appropriate I recuse myself from further participation in this thread.
