PLX Kiwi OBD Wifi device on a C32 AMG
Old Oct 1, 2011 | 12:42 AM
Wilsophia's Avatar
2002 W203 C32 AMG / 1997 Toyota Corolla AE110
Dear all,
I would like to install a boost gauge to monitor the superchargers status, but understand that the A pillar pod is not a good choice to C32, finally I check there are some OBD connected device can connect to C32. The one Kiwi having a reasonable price but not much information about it.
Did anyone connect a Kiwi OBD wifi device to a C32?
1) what real time data can be seen ? Intake temp and boost?
2) fault code diagnostic can be done too ? Can erase the code too?
3) the response time of the real time data is fast and smooth?
Because, I search on Internet, most of the Kiwi are connect to the Japanese car, I am not sure if it can fit out C32
Old Oct 1, 2011 | 12:43 AM
chris.bachman's Avatar
a car.
I use a cheap ebay OBD-II PLX Device with Torque on my Android and it's pretty sufficient. I can get IAT, Boost and lots of other information. ANd yeah you can read and clear faults.
Old Oct 1, 2011 | 01:38 AM
Robert AMG's Avatar
Cls63 & C32
i use the same ebay obd plx bluetooth, and it is working fine, Chris how do you read fault codes and clear it with this device?
thanks.
Old Oct 1, 2011 | 09:08 AM
a car.
I have an app on my Android device called Torque. If you use an iPhone then the comparable app is called Rev.
Old Oct 1, 2011 | 12:59 PM
Robert AMG's Avatar
Cls63 & C32
same i have the Torque software but where you can read and clear codes?
Old Oct 2, 2011 | 06:42 AM
Wilsophia's Avatar
Can anyone please list out all the real time data which can show in an iPhone app?
Such as: RPM, Speed, intake temp., boost, water temp, oil temp.....!????
Many thanks
Old Oct 2, 2011 | 09:14 AM
a car.
Wilsophia, google the app and read about it. I feel we've given you enough information to get started, no one is going to do your research for you.
Robert, it's the OBD Fault Check option in the app that reads and stored CEL's.
Old Oct 2, 2011 | 09:17 AM
Wilsophia's Avatar
Chris,
Thx for reply first of all, I have th apps in my iPhone already and understand how much or what info can be shown. But don't know what information can the C32 ECU can provide to the Kiwi. That is my point!
Regards
Wilsophia
Old Oct 2, 2011 | 11:42 AM
OverDrive's Avatar
Volvo
Have a look at this
Program is called Rev
http://www.youtube.com/watch?v=91aPZiBNzf4
Old Oct 3, 2011 | 11:37 AM
Wilsophia's Avatar
Got the Kiwi today but very sad........
My iPhone 3GS can detect it after configure the correct fix IP, the green tick on the left top corner is on and showed he battery voltage! but go inside I all the real time data cannot be shown........
My fd's iphone4 can do it.......
Dunno why, Any comment?
Old Oct 3, 2011 | 01:46 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Should work, it worked before on my 3G, before I got my 4. Contact their tech support.
Old Oct 4, 2011 | 12:28 PM
Wilsophia's Avatar
After del and re install the app, it work!
