C32 sensors to switch?
Old Oct 6, 2011 | 12:14 PM
Mitchell_NY's Avatar
c280 1998, 2002 C32, 2000 Ford Excursion
Hey, trying to do a bunch of things at once to the car. I dont drive it much at all, maybe a 2000 miles per year. I have 84 k on it. It is an 02. what sensors should I be looking to switch? I just want to get everything done at once, and not deal with something later.
Old Oct 6, 2011 | 01:26 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
hmmmm.......... not sure what ur asking, if ur car is running fine then why replace a working piece, but if you have a few $$$ to burn do some light modifications such as the IC pump and relay, CPS sensor, resonator and 2ndary cat delete, IC isolation kit, and k&n drop in filters.
Old Oct 6, 2011 | 04:20 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
if it's an 02, you should look into replacing your radiator. See if it's a Valeo and if it is, change it to a Behr.
Search for Glycol Contamination...
