Front and Rear spacer, different ? Why ?
Subscribe
Oct 8, 2011 | 12:32 PM
Dear all,
Having a set of republica AMG 18" rims with unknown offset, just know need add a 5mm spacer at the front to made clearance between tyre and suspension. However my spacers are not Hub centric and cause some vibration.
Want to add 10mm at front and 15mm at the rear which Hub / wheel centric spacers. Searched in here and eBay. Those M.Benz front and rear spacers are different which can't swap installation. Bu when I took out my wheels and see, there is not any different at the front and rear hub.
Why ?
Reply 0
Oct 8, 2011 | 02:38 PM
The front's hub is different - there is a small lip that you have to clear.
Hubcentric is the only way to go if you're going to use spacers. Good luck.
Reply 0
Oct 8, 2011 | 02:41 PM
Thanks for reply...
Ok, Hubcentric means the spacer center bore should be 66.5mm to fit the hub, how about rim centric? The spacer need a lip with outer diameter 66.5 to fit the rims?
Reply 0
Oct 8, 2011 | 06:26 PM
Don't buy anything but H&R spacers. Once you get the spacers you'll see why they're different for front and rear.
Reply 0
Subscribe
Currently Active Users (1)
