IAT over 100C read by Kiwi but car running ok!
Old Oct 5, 2011 | 03:07 AM
Wilsophia's Avatar
2002 W203 C32 AMG / 1997 Toyota Corolla AE110
Dear all,
Got my 2002 C32 without mod and bought also a Kiwi Wifi OBD reader. Do the real time gauges monitoring and found that IAT is around 100-110C, ECT around 85C at a highway running. The boost stool come with normal and car performance is still good.
Understand that SC will cut out by ECU if IAT is over 93C but I m not now. just want to know is the problem with the Kiwi detection or what!?
Old Oct 5, 2011 | 09:08 AM
loudandheard's Avatar
C32/C55 AMG
Is this the same temperature as the on board computer reads, the temperature right after the mileage?
Old Oct 5, 2011 | 09:43 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Are you sure you don't have your C* and F* mixed up?
Old Oct 5, 2011 | 10:11 AM
Wilsophia's Avatar
Confirmed that is degrees C not F), and I read it from real time In. Temp.
There is no fault code, everything is normal, where is the intake temp sensor?
Old Oct 5, 2011 | 07:43 PM
320 dreamer's Avatar
2003 porsche 996 turbo
sensor is located in the y pipe below the t/b.
Old Oct 5, 2011 | 07:55 PM
Wilsophia's Avatar
Thanks, can it be reached if remove the Y pipe? Or need to take out the whole SC ?
Btw, what is t/b?
Old Oct 5, 2011 | 08:08 PM
below the throttle body. no need to remove the s/c. remove the y pipe for the intakes. below that is the y pipe for the manis. you can see the iat sensor. squeeze the clips and wiggle it out then remove the plug
Old Oct 8, 2011 | 07:56 PM
Autotechnica's Avatar
2002 C32 AMG
That's way to high, I monitor my OBD2 IAT's via Dashdaq and they read ~45 degrees C during cruising. The hottest they get at WOT is ~70ish degrees. There's def something wrong and I'm surprized your S/C hasn't shut off as it's supposed to disengage at 93 degrees C.
