Valvetrain q's
86 16v turbo, 02 c32
Valvetrain q's
Does anyone know the valve length and size's for the c32's? I can't find anything about it. I would like to know overall length, stem size, and face size.
Kevin
Kevin
Moderator Alumni
Ya should hit up exotic metal (on the e55 forums) or jerry @ eurocharged. I believe both have had experience in the m113k and m112k heads + valve train.
C32/C55 AMG
This might be useful, check out this link: http://www.crossfireforum.org/forum/...ine-specs.html
SPECIFICATIONS - ENGINE
ENGINE SPECIFICATIONS DESCRIPTION SPECIFICATION
GENERAL SPECIFICATIONS
Engine Type 90 ° Bank Angle Liquid Cooled with Dual Tuned Intake Manifold and Twin Ignition
Displacement 3.2 L (195.2 cu. in.)
Bore 89.9 mm (3.54 in.)
Stroke 84 mm (3.31 in.)
Valve System SOHC 2 Intake and 1 Exhaust Valve per Cylinder Roller Rocker Arms
Compression Ratio 10.0:1
Brake Horsepower 215 (160 KW) @ 5700 rpm (67.2 bhp/liter)
Torque 230 lb. ft. (312 N·m) @ 3000 rpm
Firing Order 1-4-3-6-2-5
Lubrication Pressure Feed – Full Flow Filtration
Cooling System Reverse Flow – Forced Circulation
Cylinder Block Cast Aluminum Alloy with Siltec Bore Liners
Crankshaft Forged Steel
Connecting Rods Forged Steel
Pistons Aluminum Alloy – Flat Topped
Compression Pressure 689 kPa (100 psi)
Max. Variation Between Cylinders 172 kPa (25 psi)
CYLINDER BLOCK
Cylinder Bore Diameter
Standard 89.900 – 89.915 mm (3.539 – 3.540 in.)
Repair Max. 90.150 – 90.165 mm (3.549 – 3.550 in.)
Out of Round 0.014 mm (.0005 in.)
Taper 0.03 mm (.0011 in.)
PISTONS
Piston Diameter 89.87 – 89.90 mm (3.538 –3.539 in.)
Piston Ring Groove Depth No. 1 3.1 mm (0.122 in.)
Piston Ring Groove Depth No. 2 3.1 mm (0.122 in.)
Piston Ring Groove Depth No. 3 3.5 mm (0.137 in.)
PISTON RING GAP
Compression Ring No. 1 0.20 – 0.35 mm (0.007 – 0.013 in.)
Compression Ring No. 2 0.20 – 0.40 mm (0.007 – 0.015 in.)
PISTON RING WIDTH
Compression Rings 1.5 mm (0.059 in.)
Oil Ring (Steel Rails) 3.5 mm (0.137 in.)
CONNECTING RODS
Bearing Clearance 0.026 – 0.054 mm (0.001 – 0.002 in.)
CRANKSHAFT
Main Bearing Clearance
Radial 0.030 – 0.052 mm (0.001 – 0.002 in.)
Axial 0.100 – 0.266 mm (0.003 – 0.010 in.)
CYLINDER HEAD VALVE SEAT
Valve Seat Width
Intake 31.000 – 31.016 mm (1.220 – 1.221 in.)
Exhaust 35.000 – 35.016 mm (1.378 – 1.379 in.)
VALVES
Face Angle 45° ± 1.5°
Stem Diameter
Intake 6.975 mm (0.274 in.)
Exhaust 6.974 mm (0.274 in.)
Head Diameter
Intake 36 ± 0.4 mm (1.417 in.)
Exhaust 41 ± 0.1 mm (1.614 in.)
Length
Intake 119.4 ± 0.2 mm (4.700 in.)
Exhaust 122.2 ± 0.2 mm (4.811 in.)
Valve Margin
Intake 1.2 mm (0.047 in.)
Exhaust 1.6 mm (0.062 in.
CYLINDER BLOCK
PISTONS
PISTON RING GAP
PISTON RING WIDTH
CONNECTING RODS
CRANKSHAFT
Valve Seat Width
VALVES
Stem Diameter
Head Diameter
Length
Valve Margin
C32/C55 AMG
SRT-6
SPECIFICATIONS - ENGINE (SRT)
Engine Type SOHC 18-Valve 90° Supercharged V-6
Compression Ratio 9.0:1
Brake Horsepower 330 (246 KW) @ 6100 rpm (103.13 bhp/liter)
Torque 310 lb. ft. (420 N·m) @ 3500 rpm
Lubrication Pressure Feed - Full Flow Filtration
Cooling System Reverse Flow - Forced Circulation
Pistons Aluminum Alloy - Flat Topped
Supercharger Helical Two Rotor Design
CYLINDER BLOCK
PISTONS
PISTON RING GAP
PISTON RING WIDTH
CONNECTING RODS
CRANKSHAFT
Valve Seat Width
VALVES
Face Angle 45° ± 15'
Stem Diameter
Head Diameter
Length
Valve Margin
Exhaust 1.6 mm (0.062 in.)
CYLINDER BLOCK
PISTONS
PISTON RING GAP
PISTON RING WIDTH
CONNECTING RODS
CRANKSHAFT
Valve Seat Width
VALVES
Stem Diameter
Head Diameter
Length
Valve Margin
