EuroCharged TCU.
Loungn, just a suggestion: PM the guy to see if you can help troubleshoot his problem offline. It may have nothing to do with your tune, but as a "tuner" its better to give the customer the benefit of the doubt before questioning their credibility or troubleshooting the problem.
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
I know you are talking about the e55 but are there any mods that should be done on a c32 for reliability? The only power mods I plan to do are pulley, ecu/tcu tune. I have already done HE, pump and needswings isolation. I plan to add a pulley saver. Are there any other mods you would recommend to keep it all together? Do the fuel rails flow enough?
SPONSOR
#32
You can rest easy.
#33
SLK32
I am running a 185mm pulley + a ton of other mods (nothing fuel related) including an EC tune and I am running on the rich side - 12.8 afr (if I remember correctly). It is not a problem to safely run a 185 pulley it just takes the right tuner. I am happy to run on the rich (safe) side at this point as I have not logged in the heart of winter and just added a set of modified intake manifolds.
#34
2003 porsche 996 turbo
with the modded mani you adding even more air to an already lean tune. be careful bro
#35
I agree with 320, for example 11.5 is a realistic conservative safe AFR for boost, with 11.8 being what most people aim for with high boost. 185 pulley means what 22psi?? that is very dangerous on pump fuel.
#36
C32 AMG
who in the bay area is the master of mercedes? how do you check your AFR? Im looking to get a a pillar with boost, aFr, fuel. any suggestions on where to get this done?
#37
C63 AMG, P30
You have to buy the app, $40, and the PLX Kiwi WIFI device, $140.
I don't have this, but people say it works great.
To check AFR, I think you would have to dyno. REV can also tell you AFR.
#38
Instead of getting that, I would suggest devtoaster REV. It is an app for your android or iphone that works via OBD II.
Also shows Fuel Consumption, Fuel Consumption Avg, Fuel Level, Engine Load, Timing Advance, Coolant temp, EVAP pressure.
#39
SLK32
12.8 is to lean for a f/i engine jeremy. you should be at 11.8 to 12.2 max. datalogg and see what i mean im guessing that over 3000 rpm in 3 or 4 your well over 13 afr and thats not healthy. when we did the dyno session yrs ago the xfire with the 181 couldnt get his afr down. wasnt a tuning issue but hardware (fuel )issue.
#40
Rev CAN show you AFR if you get a bung installed and buy another sensor, but normally it will not.
#41
#42
SLK32
I have the modified AMG manifolds from Rob (Needwings). The manifolds are great. Just too many pieces on the SLK32 to run the Needswings manifolds. I would have to replace the E55 intake with Rob's DCA and replace the front grill with one like you are running.
The car already had traction issues on street tires. It is nice to have the power but it sucks having to back off the throttle at 50+ mph because of lack of traction.
#43
#44
SLK32
i have robs dual cai and the big manis as well as my ypipe ported polished and thermalcoated. should make some serious power when its back together. finally got my wheel off so paddle shifter os beoing finished up,\. then its on the true dual exhaust with slk350 mufflers and the front lip install want everything done for timmayfest!
I have the SC y-pipe from Rob polished & thermalcoated as well as the SC snout being polished, flow coated, and thermal coated.
