Never ending saga with world's slowest C55 AMG.
I can't really see the 02 sensors being a problem because what are the odds that BOTH are bad, but maybe the maf being bad from the get go ruined the 02 sensors? Who knows, but I am actually going to install new ones anyways since the car has almost 100K on the oem sensors.
try and flush that rail though, il take you 5 minutes , worth a try
Have engine on, put plastic bag around the rail to dump fuel into and push the nipple and let it squirt fuel out for a bit.
Also is your MAF Bosch original with matching part numbers?
IF it is you might try and get the MAF re-calibrated like I did
I also did a compression test and everything was fine.
I've checked everything guys, The maf is new and oem, the 02 sensors are new and oem as well, the plugs are new and the car still feels like a turd and it still runs lean.
Can anyone remove their engine cover and see if this actuator moves by revving their car in park? I see it has a solenoid so I don't know if the car will activate it in park.
It seems like you have checked everything.. Idk what to tell you..
The car came with a renntech airbox so no signature on it...lol.
If someone can give me a logical explanation as to how this could be an issue I will purchase a fuel pressure gauge and install it ( or just point me in the right direction to a really cheap one...lol ).
BTW- I bought a fuel pressure gauge. Will check tomorrow the pressure and see. What is the pressure suppose to read? In my E55 it reads 80ish psi.
From what I understand, it's supposed to occur at 3900 rpm...
Thanks.
This would explain all the symptoms...sucks I had to wait to get pissed off enough to buy a fuel gauge just for this but it seems to have been worth it.
I need someone to be SURE it's low before buying a fuel pump...they are hella expensive...lol
How can I find out what MB specs are for the fuel pressure? I've searched EVERYWHERE with no luck.
I checked voltage and had my friend turn the ignition on and it read exactly 12V. I had the pump unplugged to check so I couldn't turn the car ON but I guess having 12V off the battery is pretty good right?
