Altitude tune for c32 amg
Old Jan 1, 2012 | 10:03 PM
dustyr's Avatar
c32 amg
I recently bought a 2003 c32 amg. its moded with 181mm pulley Jerry tune ,johnson pump, larger exchanger and custom exhaust. The car was initially set up at 18 ft elevation .Where I live the elevations average over 2000 ft. Do I need to have the ecu flashed for the higher elevations? So far no issues,but seems to run slightly richer due tothe thinner air. thanks dusty
Old Jan 2, 2012 | 08:22 PM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
I informed Eurocharged of my areas altitude 5000+ft, and they did adjust tune. Not sure if an adjustment would be required for 2000ft. Give them a call and found out. Don't forget too that the tune has improved over time. So if it's outdated I do suggest retune.
Old Jan 6, 2012 | 01:55 PM
dustyr's Avatar
c32 amg
thanks for the info. I called and I should be OK up to 3500'. The tune and pulley upgrade was done in april '11. should be OK. Now, if I can find "dip sticks " for the engine and tranny , I guess its an "old school" thing ,but I work with level sensors,all types and they can and do give false readings. thanks again for your help. dustyr
Old Jan 6, 2012 | 05:03 PM
Quickvr4's Avatar
05 C55 AMG
On fuel injected cars once you set a tune you should not have to touch it. This is what a mass air sensor is for.
Old Jan 8, 2012 | 03:42 PM
dustyr's Avatar
c32 amg
mass air flw sensor
Agreed, fuel injected cars are affected less by altitude than carburated ones. The mass air flow does compensate to a large degree to altitude changes, but establishing a new ecu baseline allowes the sensor to operate in a more efficient way. instead of the ecu getting a lean signal all the time at higher elevations where you live, the ecu now "sees" a normal mixture at altitude. This recenters all operating parameters resulting in better engine management in other words MORE POWER !!
