c32 amg
c32 amg
hey guys i have a question i just bought a c32 and it has the 181 pulley on it i dont kno the brand but how can i tell if it has and ecu program on it.
I am not 100% sure but I don't think you can without using a reader.
Most people get the speed limiter removed and the redline increased so you could look at these. Unless there is a tcu program also then it will probably shift at the stock points? otherwise you probably don't want to go over 155mph just to find out.
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
To load software, the ECU needs to be opened. Given that, check your ECU for signs of being opened. Contact Eurocharged to see if they can help. If you also know the name of the previous owner, they may have a record of doing a tune. EC was the largest (if not the only) supplyer of the 181mm pulleys. You may also be missing some maintenance on the pulley and the software.
I thought you could load software by using eurotune or the remote cable via the diagnostics port? and therefore ecu may still be untouched?
2006 E55 Amg
Porsche 2004 911
http://www.letmotorsports.com/ECU-Re...structions.pdf
I have never opened or removed the ECU so I am advising without experience on this one; the pdf attached and below link may help you,
1 Post
1996 S420 2006 C55AMG 2002Mustang GT
jason you gotta get in with AMG of the northeast... were a large group of tristate Mercs and AMGs, and some other high performance cars we always have meets and cruises going on in the queens, LI area. PM nladam12 your email address well get you on our mailing list and get you in the swing of things. Waveykat you too!
Jeyssallem84@yahoo.com
