Blue top solenoid c55 info??
Old Mar 12, 2012 | 09:24 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Originally Posted by mikekuriger
I put my brown tops back in after a few months with the blue tops. Shifts are only firmer at low throttle. full throttle shifts are the same as stock. downshifts are harsh and blew out my brand new motor mounts within 2 weeks. Not a good mod IMO.
If the TCU can be reprogrammed not to shift harshly during downshift it would be ok. also, when dropping into passing gear on the freeway, the clutch is let out before the engine can rev up causing a buck - similar to a bad driver trying to downshift a stickshift.
That's more than enough reason to abandon this. I'll stick with my plans for the Quaife diff.
