Needswings C32 Cold Air Intake
I've prepped her by explaining that i'm going through the car and maintaining it. I had to replace the S/C clutch last month because the bearing was bad. She could tell the difference in sound (better now) and also recognized an improvement to the performance. This is a good setup for me now that I'm going to change the pulley, add a tune and install a H/E and I/C Pump all under the guise of doing periodic maintenance.
Update- I was speaking to her on the phone as she was going to work this morning and commented that she was getting onto the highway and said..... "the car is running much better. No one can come near me now." but you need to know my wife is one of those who don't care about performance and is actually afraid of it.
Score one for me!
Score one for me!
"...It's weird honey. All of a sudden the tires have awful traction...."
Catching you? Steve, this is a W203 forum.
As previously mentioned, I initially installed the Needswings CAI first before installing the pulley, heat exchanger and pump. I noticed the difference in the pickup and absolutely loved the change to this single mod.
The second phase was to install a heat exchanger and a Johnsom CM30 IC pump. I purchased both through EBay for $425. I thought that was a pretty good deal. Both were easy to install. I drained the entire coolant system and got approximately 1.75 gallons out. I put back in 3 gallons! Everything works fine. No leaks. Good to go.
Just installed the Eurocharged pulleys this past weekend. The car now has the 185 pulley on. Toughest part of this install was getting the belt back on which leads me to a question for all of you guys who know way more about this than I do. Mind you, i don't yet have the tune installed. The car is hesitating a bit at higher rpms during initial acceleration and seems to be a slip in the belt. Being how difficult it was to put a new belt back on I find it difficult to believe the belt is slipping. Can if be too tight? Can it actually be slipping? Does the tensioner set the tension automatically or do I need to adjust it. Can it be something with the fuel or timing that will get corrected once I install the tune?
You guys are always great and I learn a lot from you all. Any advice you can lend will be appreciated. I expect to get the tune installed sometime this week when Eurocharged is availiable. Thanks! BTW, no real improvement noticed since installing the CAI. Hoping that the tune will be the difference maker. Stay tuned................
A couple tips:
1.) Make sure you did not tourque your water pump pulley down too tight...its easy to do and has caused more water pumps to be replaced once it seizes than anything.
2.) Get needswings pulley save kit...it does reduce wear on pulleys, but it makes getting belt on and off much easier, IMO (does for me).
Can't say anyting about teh hesitation thoug
Yet another awesome mod only available to those cars!!
Rear axles is another story however. I had mine snaped once at the track. And I hear it happend to a couple of CLKs.
BTW, just received part 2 of the project from Rob at NeedsWings. I had the SC inlet modified for the 80mm TB and Rob had it sand blasted and coated inside and out along with the lower y pipe.
It just seems like overkill. I've seen what seems like smaller intakes on 800+HP vehicles. No doubt though the intake looks good and was obviously designed with a lot of effort. I do like it. The price is up there, but what isn't on an AMG Mercedes... Thinking doing a good custom camshaft with 185MM and supporting mods would make a monster out of this intake system.
On a side note, I'm close to waking up my Igor. The intake was already on. Added the looped fuel rail and an 80mm TB. Hopefully tomorrow.
Since making the other changes I note the following-
1) I believe a heat exchanger / IC pump upgrade is valid espcially since I have a '03 with originals.
2) The pulley ane tune upgrade is not as noticeable as I was led to believe. The CAI is without question noticiable. If I did improve at all with the pulley and tune it isn't with the same magnitude. I'm also having some unresolved issues from this Eurocharged tune. When aggressively accelerating I throw misfire codes. Eurocharged recommended I go back to OEM wires. My magnacores are relatively new and don't want to spend $200 on a "maybe".
Bottom line- I'm a bigger fan now after the tune with Rob and Needswings for their CAI. With all sincerity- this is the first thing everyone should get and quite possibly the only thing. I'd love to hear more from others who have this installed. I'd like confirmation on what I really believe is a good thing.
Peace
Anthony, a good friend of mine and Steve (320 dreamer) blew his diff at the track two weekends ago. Anthony is as good/talented a racer as I've ever met. Steve himself had to replace the rear in his SLK with the Wavetrac, luckily he caught his before it got nasty. I'm crossing my fingers every time I mat the throttle.
Cheers,
Cheers,
This observation would surprise me too.
I guess they never planned on us running consistent low 12's, ha.
Carry on
