Eibach Rear Sway for C32
C63 AMG, P30
Hey All,
So I'm getting sway bars for my car and want to know why the Eibach sways are not listed for the C32. I just want the Eibach rear and the H&R front.
This seems to be the best combo from the research I've done.
Will the Eibach sways work for the C32? It list them only as the W203 Coupe and Wagon fitment.
I did a little searching and found that W203's share the same rear so will it work?
Also, if any one has some sways for sale let me know. I can trade my stockers with cash on top or just buy outright.
Thanks!
Thanks!
1 Post
2003 C32
I have the Eibach sways installed. They were a straight forward swap. The part number listed for the w203 coupe are what I have.
You will need to drill carefully the front bar holes to 12mm. If you get the H&R front, get the regular w203 one and drill it, you'll save $ compared to the one listed for the C32.
Hey All,
Thanks!
Thanks!
C63 AMG, P30
I've read to get the H&R front and the Eibach rear. Is it advisable to switch brands? Or should I just stay with the H&R kit?
Thanks for the advice btw!
1 Post
2003 C32
Your preference really depends on your goal. A thicker front bar will generally increase under steer as will a thinner rear bar. Since I track my car, I went with the Eibach combo as it gives me the best setup to reduce lean and understeer at the same time.
I started out with the H&R rear with stock front, then added the Eibach front, then changed to the Eibach rear from the H&R.
What ever you choose, they are both quality products.
2005 E55 AMG
Do you still have your old H&R rear?
The H&R front with Eibach rear gives you the thickest bar combination readily available.
C63 AMG, P30
Alright, I'll take your advice and grab H&R front and the Eibach rear.
Thanks for you help.
FYI about bars
Stock: 20 mm front and 13 mm rear
C32: 22 mm front and 16 mm rear
Evosport: 24 mm front and 19 mm rear
Eibach: 24 mm front and 22 mm rear
H&R: 26 mm front and 19 mm rear
The C32 front bar is 46.4% stiffer than stock.
The C32 rear bar is 129.5% stiffer than stock.
The Eibach and Evosport front bars are 107.4% stiffer than stock.
The H&R front bar is 185.3% stiffer than stock.
The Evosport and H&R rear bars are 356.3% stiffer than stock.
The Eibach rear bar is 720.2% stiffer than stock.
The Eibach and Evosport front bars are 41.6% stiffer than C32.
The H&R front bar is 95.1 % stiffer than C32
The Evosport and H&R rear bars are 98.9% stiffer than C32.
The Eibach rear bar is 257.4% stiffer than C32.
The Eibach rear bar is 79.8% stiffer than Evosport and H&R.
The H&R front bar is 37.7% stiffer than Evosport and Eibach.
The stock front bar is 460.2% stiffer than the stock rear bar.
The C32 front bar is 257.4% stiffer than the C32 rear bar.
The Evosport front bar is 154.6% stiffer than the Evosport rear bar.
The Eibach front bar is 41.6% stiffer than the Eibach rear bar.
The H&R front bar is 250.7% stiffer than the H&R rear bar.
My only concern with the HR kit is that with that HUGE front bar, and staggered tires, you MAY have an understeer condition on your hands. I would certainly like to see it, with UN STAGGERED tires all the way around
C63 AMG, P30
Alright guys, I just got my sway bars on today. DAMN! They literally have transformed the car... The steering even feels heavier and the whole car just gives you a difference cornering confidence that was not present before. The whole car feels much more stable during the turn and exit.
I just can't wait to get Michelin Super Sports and a good alignment!
My Dunlop DZ101's are lasting too long. The front that is lol
Anyways, quick question. When driving I am getting a random knock that comes from the rear? It is annoying and I want it gone!
Is it an installation problem?
Do the bushings have to break in or become more malleable?
More grease for the bushings?
Any help would be great!
1 Post
2003 C32
I had to trim the cover on the lower control arm for my installation. The bushings shouldn't need breaking in. Did you replace the end links? Highly recommended as the thicker sways will put more stress on them. There was a post a while back to install a washer on the the rear end links to prevent the bushing from piping out. This may be your source of the knock.
C63 AMG, P30
Do the rears need them as well. And I'm trying to find the sway bar washer thread but I haven't been able to find it.
Thanks for your help
Super Moderator
https://mbworld.org/forums/c32-amg-c...ure-point.html
Although the links may not be the source of your noise, they're often irreparably worn.
Was about to jump in, but you beat me to the punch
C63 AMG, P30
Alright, I just took the bolt out and I'm going to go to OSH and get the washer. It's weird though. I never have the knock noise before the new sway bar. Any other suggestions?
C63 AMG, P30
For some reason I am getting more of a creak now when driving on un-smooth surfaces. My friend told me to grease the bushings, as the shop might not have done a good enough job at doing so.
Question: What are the torque specs or the sway bar bushings?
I'd really like to get everything dialed in the right way and keep the sound to a minimum. I'm all for a performance car, but not one that creaks and rattles during everyday driving.
C63 AMG, P30
So I went up a driveway today, angles of course to prevent scratching my carbon lip, and my rear tire actually came off the ground!!! I adjusted the sway bar to the softest setting in the rear! This is nuts. I don't want to say that the sway bars suck, but if I hit a corner hard enough is the inside tire going to lift?
This can be right, as others have the Eibach rear which is even stiffer?
I'm thinking its my OEM shock/ H&R springs combo not pushing the rear wheel down hard enough...
Any insight?
Any time you go with a larger rear bar, you do indeed risk it lifting the inside wheel. I had this happen to my 91 stang, when I had Eibach make me a customer rear bar. It really played hell on my Auborn, which I blew out in one day out at Nelson Ledges.
Not really a fix here, other than what was explained above, aka going to its softest setting.
Anytime you use a thicker swaybar to tune oversteer or understeer you will add more lift to the inside tire. You have to way this lift which could mean less traction out of the corner against increased cornering speeds.
I would not worry about it lifting the inside tire off the ground as in normal driving on the streets and on the track you will not encounter driveways.
If you like the stiffest setting just leave it there. My rear bar is stiffer than the Eibach and I could care less about the inside wheel lifting.
Only way to fix this would be to use stiffer rear springs rather than a stiffer rear bar but then you have a car that rides real harsh and would be unbearable on the street.
