Star Diagnosis Vmax C32 AMG
Old Mar 18, 2012 | 05:29 AM
mercedesfreak29's Avatar
C32 AMG
Hi all. Maybe someone can help me. I'm from Germany, so my English is not so good.
Have the following problem:
When I go to my star on ECU diagnostic 2.8ME drive-motor-controller Implicit coding, I'm only in 0224 several 250 km / h versions to choose from, but the C32 should also be 280 km / h his presence.
Is there a solution?
Stephan
Old Mar 18, 2012 | 05:40 AM
Robert AMG's Avatar
Cls63 & C32
Stephan
You will not find more then 250 km/h in star coding you need a tune, a reflash, a new software for the ECU.
Old Mar 18, 2012 | 05:48 AM
C32 AMG
Can I make it myself with the star diagnosis
Old Mar 18, 2012 | 05:51 AM
Robert AMG's Avatar
Cls63 & C32
No you need a tuner.
Old Mar 18, 2012 | 06:26 AM
C32 AMG
But I seen it in pictures like a W211 E55, the selection of up to 300 km / h is available. Is the problem only when c32 AMG?
Old Mar 18, 2012 | 06:33 AM
Robert AMG's Avatar
Cls63 & C32
I don't think there is a 300 km/h available for E55, maybe i am wrong.
Old Mar 18, 2012 | 06:59 AM
C32 AMG
Look here.
https://mbworld.org/forums/w211-amg/...-diy-mods.html
Old Mar 19, 2012 | 02:35 PM
Robert AMG's Avatar
Cls63 & C32
This is for 63 engines.
Old Apr 2, 2013 | 04:06 AM
standman123's Avatar
Mercedes C55 T AMG
Hi all,
I have a question. I have a Mercedes C55 AMG T and Star Diagnosis Developer.
Like my Vmax would lift or remove.
I was already in the engine control unit with developers because it says invalid encoding exist! the code 0224 can lift the Vmax to 280! But if you do it and test it sealed off at 250!
Does anyone have an idea?
Thank you
Old Apr 2, 2013 | 03:34 PM
Robert AMG's Avatar
Cls63 & C32
Originally Posted by standman123
Hi all,
Thank you
when you have to change any code in the developer you have to erase all faults in the ECU, or it will not take the new code.
Old Apr 2, 2013 | 03:47 PM
Mercedes C55 T AMG
sorry robert amg, i am not understand you.
Old Apr 2, 2013 | 05:58 PM
Robert AMG's Avatar
Cls63 & C32
just clear erase the fault codes stored in the ECU control module then go to control unit adaptation and change the code to 280.
Old Apr 3, 2013 | 03:35 AM
Mercedes C55 T AMG
I deleted the fault memory. Then I put the code 0224 to 280km / h! I drove on the highway, but he's locked down at 260! Then I again made diagnosis star turn but the code was out again!
