C55 Spark Plug question!
Hi, Im able to get a very good deal on a set of Spark plugs for M113 430 engines. I know there the same as the 500 spark plugs but does anyone know if they are the same as my M113 C55 engine? I'm able to get a smoking deal on these so hopefully these will fit!
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
If you have the sputter, its not spark related but fuel.
I have checked smooth running values at idle. Where I am noticing the issue. Number 2 and 8 were out of there specified values. (-3.50,3.50) cylinder 2 was intermittently at 5.05, cylinder 8 was at 4.42. Since spark plug wires it has been better. But I think to eliminate the problem spark plugs would be good. I will swap coils.
**i have looked into smooth running values fault counter, nothing is present**
QUOTE=kent426;5152169]Are you pulling a code or does the car jsut sputter at idle a bit. You can run NKG plugs for $2 each instead of the Bosche at $7 each and notice no difference. I changed mine at 40K.
If you have the sputter, its not spark related but fuel.[/QUOTE]
