HELP!! non staggered wheel fitment on C32 - Need answer quick
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hey everyone,
Anyone know if a non staggered setup: 18" x 9.5" AMG rims with Bridgestone Turanza 255/40R18 95Y tires all around will work on a C32?
If yes, great!! If not, is there a way that I can get them to fit? How much would it cost?
I hope to get an answer soon, the seller is waiting on me to respond on a set that im looking to buy from him...thanks guys
Hey guys thanks for your feedback! I have one question left that i really need answered before 5 pm EST today before I meet the seller.
The rims are a non staggered setup of 18" x 9.5" AMG rims all around. I know several of you mentioned that the tires will be too big in the front (Bridgestone Turanza 255/40R18 95Y tires all around).
Does that mean that the rims are ok all around, but all I will need is to get smaller tires in the front? If so, what tires should I look for?
If not, do i need diff tires and rims in the front?
Thanks guys!
Thanks guys!
C32, 911 SC
It really depends on the offset of the wheels. Right now, i think 9.5 width for the front is way too wide. My 19 is 8.5 for the front with 37 offset and i am milimeters away from brake calipers and the struts. It also sticks out a little but from the front fenders. If you can do a test fit prior to buying, that would be great.
MBworld Guru
white and whiter
will not fit.
1. wrong size tire up front
2. wrong size tire in the rear. right width, wrong profile.
3. 44 offset doesn't even fit the rear without 10mm spacer
4. 44 offset definitely does not fit the front with 9.5 width.
5. If you want to run non-staggered. max you can run is 9" width with some 30-35 offset with 245/35 if 18 or 245/30 if 19.
Thanks guys, your comments were very helpful and saved me a bad purchase. Could you guys please check out the new thread i posted titled:
New 18'' AMG wheels purchased! Will these fit?? Help!!
I just purchased new wheels and I could use some more advice. Thanks!
